accessory power?
Old Jul 28, 2005 | 09:45 PM
jrtf83's Avatar
Question accessory power?
Hey fellas, i'm wiring a buncha stuff into my car and i need to find the easiest place to get accessory power, like power when the key is on. What i'm going to do is wire a relay into the cigarrette lighter adapter so that my radar detector doesn't drain my battery and buzz like a madman when i'm in grocery store parking lots. Also, i need an acc power for the power supply for the computer i'm putting in my car. Thanks in advance fellas.
Old Jul 29, 2005 | 07:08 PM
BigEvil's Avatar
Re: accessory power?
Pull the fuse box out of the side of the dash and splice into the wire coming out of the back of the "radio" or "acc" fuse. You can check them with a test light. Put the light on the exposed metal and the light should be off, turn the key on and it should come on.
Have fun, it's not difficult.
Old Jul 31, 2005 | 09:35 AM
bt96ss's Avatar
Drop the dash panel (it's easy) and wire to the pink wire in the main ignition harness. If you want to have power when the key is turned back wire to the brown wire. No relay requires.
Old Jul 31, 2005 | 04:36 PM
jrtf83's Avatar
thanks guys but what i ended up doing is drawing it from the back of the radio, one of the yellow wires is ign.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
XtremeLt1
Sep 13, 2002 08:50 PM
