1 fuse from double distribution block keeps exploding!!!
Old Apr 4, 2003 | 05:36 PM
Skull Leader's Avatar
Angry 1 fuse from double distribution block keeps exploding!!!
Not exploding, but strong enough to pop the glass each time. I just got a new 2.4 farad capacitor, and the 60 amp fuse to my Lanzar VHC turns red hot and bursts immediatly after flick the power switch on (made from a battery disconnect). Why is that amp drawing so much power? My 400 watt Jensen (yes I know it's crap but it was practically free from Worst Buy) works fine. Both amps worked 100% great till I installed that cap. I'm pretty sure I wired everything right too.
I already wasted 4 fuses trying to find the problem, and those junks are $5.00 for a pack of 2!!!
Old Apr 5, 2003 | 02:51 AM
x7x7's Avatar
A small diagram of how you have things wired might help but from your explanation I'd say that there is a direct short somewhere. Double check your connections and make sure your power wire on that side of the block isn't shorting to something. If everything is fine there could be a short inside the amp. IS the fuse in the amp still good?
BTW, did you get a chance to take a pic of your sub box in the car yet?
Old Apr 5, 2003 | 08:22 AM
LS1 RULZ's Avatar
From your description I'd say you have something wired wrong. If the fuse pops that fast you've probably got a dead short someplace in your wrirng.
Old Apr 5, 2003 | 08:46 AM
LWillmann's Avatar
I agree that a wiring diragram or at least description will make things much easier.
Did you charge the cap before connecting it?
If the fuse that is blowing is between the cap and the battery, then your cap might be pulling tons on juice to charge itself and blow the fuse.
It sounds like if it's not the cap attempting to charge, that you have a dead short somewhere.
Old Apr 5, 2003 | 10:59 PM
Say, what is this "dead short" you cats speak of? I didn't have enought time today to look for any shorts and it's dark now, but I'll check in the morning. I wired it different from the instructions cuz they just sucked. Says there should be a cap for each amp, which I am not about to do. I have...
positive from battery--- to cap--- to fused power distrubution block--- to 2 amps
ground to cap--- to ground block--- to 2 amps
The cap is charged correctly too.
x7x7, I'll try to take pics tomorrow when I pull check my wiring.
Old Apr 7, 2003 | 09:34 AM
LWillmann's Avatar
A dead short is when a positive and a negative meet. Just another way of referring to a short. Although a dead short is usually a more extensive one.
A basic short could be a single strand from the positive touching the negative wire or connector on the amp, and a dead short would be like the whole positive cable touching the ground.
You might want to make sure you don't have just a conductor or two that's arcing over.
Old Apr 8, 2003 | 04:32 PM
Question
The thing is, my amp works fine without the damn cap. Are there websites that show exactly how to wire a cap?
Old Apr 8, 2003 | 06:09 PM
x7x7's Avatar
there's some general info here: http://www.eatel.net/~amptech/elecdisc/capacitr.htm
make sure you have the polarity right. From your description it sounds like you have it wired right. How did you charge it?
If it's only one side of the block that's blowing then there must be a short after the block on that side.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
JSK333
Sep 9, 2002 10:33 PM
