Will there be both a C7 Z06 and ZR1?
Old Aug 2, 2013 | 09:20 AM
Z28x's Avatar
With the new LT1 putting out LS7 like tourqe and the rumors of there being no larger engines it seems like the Z06 might be dead. What engine would fit in between the supercharged or turbo LT1 in the ZR1 and the 460HP Stingray engine?
Z06 was always the lighter car, but the Stingray already has the aluminum frame. I just don't see a Z06 with the C7.
Old Aug 2, 2013 | 11:37 AM
King Moose SS's Avatar
Re: Will there be both a C7 Z06 and ZR1?
I thought the ZR1 was a one time sort of deal.
Old Aug 5, 2013 | 12:49 PM
ImportedRoomate's Avatar
I have a feeling that the LT1 might have some more in it if you go for performance instead of efficiency.The jump from the L99 to the LS3 is a good indicator. Give it a Z/28 style treatment (maybe not as extreme) and there's your Z06. The ZR1 will stay with the all out power, full interior and features.
If they do come out with a Z06, its going to be a handling monster. The Z51 is already pulling 1.11G in MT's skidpad tests. The last Z06 was "only" pulling 1.08G.
Old Aug 6, 2013 | 03:01 PM
SSCamaro99_3's Avatar
I could see it as perhaps a track oriented car, maybe remove the cylinder deactivation so you can turn more rpm/more agressive tune. I doubt you will see a 7.0. The big bore was difficult to keep clean as it was. Perhaps I am wrong (I would love to see a 7.0 DI engine). I think there is room for a car with more tire/suspension/brake and a modest bump in power. I am sure a little tweaking would take it past the LS7 without too much trouble.
Dry Sump, more agressive cam, lightweight rotating assmbly, and the extra rpm may be able to match the previous LS3 to LS7 spread.
Old Aug 7, 2013 | 09:49 AM
Z28x's Avatar
Good point about the L99. On top of that they could add all the titanium parts like the LS7 had and throw in a more aggressive cam. Low 500HP should be easily achievable. LT2 or LT7 would be a good engine name (please GM don't call it LT4).
Old Aug 11, 2013 | 02:45 AM
AdioSS's Avatar
West South Central Moderator
LT5 maybe? Or would that be best for the next gen ZR1?
I think it is very cool how close the LT1 torque curve is to the LS7's.
Old Aug 12, 2013 | 10:48 AM
Z28x's Avatar
I hope they don't reuse that name either. It makes things confusing. I'm already not a fan of them using LT1 again so soon. I wish they waited for the C8.
Old Aug 12, 2013 | 11:09 AM
Its been 17 years since the last LT1. That's about the same amount of time between the original LT1 (sold from 1970-1972) and the last LT1 from (1992-1997) - 20 years difference.
Old Aug 12, 2013 | 06:20 PM
99SilverSS's Avatar
Yes interesting points. Even with the aluminum frame the C7 is heavier than the C6. So a lighter Z06 would likely require either removal of content or using lighter and more expensive materials.
I haven't heard the rumor that the largest displacement Gen V engine is already out at 6.2L. There are certainly options to built up an LT1 internals and make it a very potent engine without increasing displacement but a new "427" has a nice ring to it.
Old Aug 13, 2013 | 09:01 AM
WhiteHawk's Avatar
I have to think that it is not going to be long before somebody builds a DI 427. Should be good for close to 600. I am surprised that Lingenfelter isn't offering a kit yet!
-Geoff
Old Aug 13, 2013 | 09:03 AM
Dan Baldwin's Avatar
1970-1972 was LT-1, not LT1!
Using the same name within 20 years is stupid and unnecessary. It's not like the 90s LT1 is revered or anything. I had a '95 Z28, and I haven't been pining away for any "new LT1".
tl/dr: LT1 = dumb name for the new engine.
Old Aug 13, 2013 | 09:26 AM
You know I actually typed it with the dash and it got lost somewhere when editing.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
football4life
Oct 4, 2015 07:48 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
alphaauto
Jul 26, 2015 04:40 PM
