What GM engines can use direct injection?
Old Feb 16, 2006 | 09:58 AM
Z28x's Avatar
What GM engines can use direct injection? and is there a time from when we can expect to see them?
The Ecotec (2.0L Turbo) and DOHC HF V6 (3.2L) already have it so I know those two families of engines are ready, but what about the Atlas inline engines? That might be all the 5 cyl needs to get ecepted by the haters. And what about the small block V8s? that is the one everyone is waiting for. I don't expect the Northstar to get it since the Ultra V8s are a few years away.
Old Feb 16, 2006 | 06:22 PM
305fan's Avatar
Re: What GM engines can use direct injection?
that could help out the Atlas 4,5, 6 for sure.
I don't know why the 4 and 5 is down on power (62hp litre and the 4.2L is 69hp)
By this logic the 4cly shold be 193 and he 5cly 241hp
Given each engine is damn near the same...
But yeah DI rocks: you can run higher comression ratio, its cleaner and mileage is better, I think.
Old Feb 16, 2006 | 06:33 PM
toneloc12345's Avatar
4.2l already has 291hp!
Old Feb 16, 2006 | 06:45 PM
305fan's Avatar
Yeah but a bit more couldn't hurt!
Old Feb 20, 2006 | 08:57 PM
teal98's Avatar
The 4 and 5 cyl engines have a balance shaft. That eats up some horsepower -- maybe 5 or 10?
Old Feb 20, 2006 | 10:59 PM
305fan's Avatar
ah...did not think of that one! Yeah somehwre between 5-10hp sounds right.
Stil, l there is a few unacounted for hp
Old Feb 21, 2006 | 04:21 PM
90 Z28SS's Avatar
The 2.2 ecotec in Europe is now a direct injection engine now with 155 standard hp . I dont see how it possibly couldnt be part of the Cobalt refresh , coming up in 08 .
Old Feb 21, 2006 | 05:55 PM
Meccadeth's Avatar
I really couldn't care less about the HP improvement of direct injection...it's really not that much. The real benefit is the increased efficiency of the combustion.
Old Feb 21, 2006 | 06:38 PM
305fan's Avatar
I suppose if you left the compression ratio the same. But it allows higher compression ratios, then you can get the max effect from direct injection.
Its alot more then Chevys VVT I think.
Old Feb 28, 2006 | 01:10 PM
Z28x's Avatar
GM could sell a LS7 with 12:1 compression making 600HP and still get the same milage.
CARiD
Jan 27, 2015 06:27 AM
ChrisFrez
Jan 11, 2015 03:47 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Jul 4, 2005 05:00 PM
