V8 370z
Old Jun 28, 2008 | 10:31 AM
Gripenfelter's Avatar
V8 370z
http://www.autoblog.com/2008/06/26/n...z-car-more-37/
Competition for the Camaro?
Old Jun 28, 2008 | 12:32 PM
Z284ever's Avatar
Whaaaaaat??? A RWD car? Which will be 220 pounds lighter? With an available V8? Well, uhm, erm, *cough*, ah - that's impossible, isn't it?
Old Jun 28, 2008 | 01:15 PM
1fastdog's Avatar
Sounds like they are "considering" it.
The previous car was 3600 pounds, I believe. Sounds as if they will shorten the wheelbase to pick up the 200 pounds for the v6.
The 370 market is Porsche Cayman alternative. A shorter WB and lighter weight might get some of the Cayman entenders to give it a peak. V8? Maybe. "considering" is usually marketing speak for "trial balloon".
Old Jun 28, 2008 | 04:54 PM
HAZ-Matt's Avatar
The 2008 350Z's curb weight is listed as 3320 lbs for the lightest version and 3498 for the heaviest automatic.
Old Jun 28, 2008 | 11:30 PM
1fastdog's Avatar
You know, you are right. I think I'm thinking of the roadster.
Old Jun 29, 2008 | 02:12 AM
VladimirSteel's Avatar
well how can they call it a 370 with a v8, that will undoubtably be bigger than 3.7 liters?
Old Jun 29, 2008 | 04:42 AM
guionM's Avatar
Not for a 2 passenger sports car. The much bigger Corvette has been doing this for years (V8, RWD, curb weight under 3200 pounds).
The chassis on the 370Z doesn't need to be built as tough as a tank either. Horsepower is a relatively modest but respectable 335. Torque is a mere 278 lbs/ft (just 30 horses and nearly identical torque of a DI 3.6 V6). A far cry from the the monsterous 430 horsepower and nearly 400 lbs/ft of chassis twisting torque of the LS3 that a car like say... a 4 passenger Camaro... will have to handle.
Old Jun 29, 2008 | 04:43 AM
Capn Pete's Avatar
Oh, there you go, having your crazy visions of a light-weight, V8 coupe again!?
Put down the crack pipe! There is no place/demand/ability for such car in today's market .
Old Jun 29, 2008 | 10:54 AM
Z284ever's Avatar
I would imagine the V8 will produce more than the V6's 335 hp.
Also, if I wanted a tank I'd splurge and get Chobham armor, 120 mm gun and gas turbine engine, not a Camaro.
Old Jun 29, 2008 | 11:17 AM
shock6906's Avatar
Incorrect. The Lotus Esprit had a 3.5 liter V8. Small bore and stroke can give you a low displacement V8.
Old Jun 29, 2008 | 11:28 AM
CLEAN's Avatar
There you go! You get the Z you want after all! The fact that it comes from Nissan is purely semantics.
Old Jun 29, 2008 | 11:56 AM
yes but i doubt nissan is going to the trouble to make a 3.7 liter v8 like lotus. I wasnt saying it couldnt be done, i just dont figure nissan will stick to the 3.7 and stay with the name.
Old Jun 29, 2008 | 05:43 PM
HAZ-Matt's Avatar
As far as the Z car goes, the V8 would be a different displacement than the V6 and likely have different numbers in front of the Z.
Old Jun 29, 2008 | 06:32 PM
Big Als Z's Avatar
It wouldnt be called 370Z. The replacement for teh 350Z is going to get the G37's 3.7 liter V6.
This would most likely get the 5.0 V8 from the FX and soon M series cars, so it would be a 500Z.
Old Jun 30, 2008 | 10:19 AM
jg95z28's Avatar
Corvette.
Incidentally, if they make a V8 Z, I may go back to Nissan.
