Next Corvette to Get All-New Small-Block
How does a 5.3L engine weigh more than a 6.2L engine? Are you including the twin turbos? In that case it would have the potential to get better fuel mileage than the bigger displacement motor while making alot more power. So it would be more like tie/tie/WIN.
Not to mention the potential of that motor, without having to perform any serious mods, would be outstanding.
First, smaller bore means the holes in the block are smaller = more weight. They aren't going to lighten up the exterior of a block or make it physically smaller to punch smaller holes in it. 4.8's have the same exterior dimensions as 6.2's.
Second, lower displacement DOES NOT equal better fuel economy.
Lastly, putting forced induction on a 5.5 is complete waste when you can put forced induction on a 6.2 and make gobs more power.
I'm not specifically talking about anyone in this thread...
Case in point:
The classic Z/28 302 V8 had a smaller displacement than the classic SS-350 V8, (Both had a 4-in bore btw.) and despite the 350 being "rated" with more hp (295 v. 290), we all know that was actually BS and the 302 had at least 100hp more than the 350.
While bigger displacement can mean more hp, it isn't the only factor in determining performance.
IThe classic Z/28 302 V8 had a smaller displacement than the classic SS-350 V8, (Both had a 4-in bore btw.) and despite the 350 being "rated" with more hp (295 v. 290), we all know that was actually BS and the 302 had at least 100hp more than the 350.
In theory you're correct. However we all know the real world sometimes blows those types of assumptions out of the water.
Case in point:
Case in point:
I know a guy that has a 68. It gets 11 MPG, according to him. Not exactly designed for fuel economy. Absolutely awesome car and I'd love to have one too.
But as long as we're splitting hairs, one could argue that the pistons for the larger diameter bore are heavier, as are the larger rods, as would be the corresponding counter weights on the crank, so technically my guess is that the larger displacement motors weigh more.
The 302 probably still got worse mileage with a single 4bbl as well. I was extrapolating to the nth degree, point is the same.
Pffftt... the problem with "real world" numbers are the amount of variables that go into them. Maintenece, driving style, enviroment, and vehicle configuration can have alot of effect on that.
The only problem I see with using the EPA test is that manufacturers probably spend alot of timing figuring out how to game the system so that they can use it to thier advantage in advertising.
in both situations YMMV
My questions for the next generation is will VVT be standard and what are the rumars for the replacement A6
& M6?
Besides, oversquare engines favor a valve limited design like the LSx. Peak flow isn't so much the issue as it is low and mid lift flow (where multivalve engines shine in comparison).
As for max engine speed, the valvetrain is more of determining factor than the recip assembly.
