Kumho launches the first ever 15 series tire
When I upgraded to 19" rims, i just went with GoodYear Eagle F1, which were actually softer despite having a much smaller sidewall.
Low profile tires are not fun to mount. Run flats are no fun to mount. Ultra low profile run flats make my head want to explode. The equipment you have available makes all the difference in the world but these are going to be a PITA no matter what equipment you have. Good equipment can make run flats and low profile almost make runflats and regular low pros a non issue but these are going to be tough even on the right size rim.
The only case where I've run into real problems is with (generally aftermarket and mostly BMW) wheels where the offset damn near made them a reverse drop wheel (that deep dish people are crazy about).
Now I cant say I remeber working with a 2.25" sidewall on anything, but the closest I can remeber is about 3.25" on a 205/40R16 BFG Scorcher (IIRC or maybe it was a Euro, its been awhile).
Cant say anything about PAX stuff, if you mess with that I'll take your word for it.
Again depends, I've mostly worked with Michelin tires and even thier low profile and runflat stuff isn't bad (Goodyear and Bridgestone on the other hand - stiff as [censored] when it comes to runflat sidewalls)
Care to elaborate? I'm honestly curious what happened. I had been rather satisfied with their tire (Kumho ecsta MX) on my Quattro Audi. The TireRack rep told me to do wheel alignment after installing tires, since they are sensitive to uneven wear. I did that, and those tires are serving me well - they don't cost an arm and a leg, and provide decent traction.
Since then I have went through about 20-25 sets of Hoosiers for my Camaro. I have also turned on many fellow autoxers to Hoosier and steered them away from Kuhmo. My Dodge Ram and Civic also received new tires and they sure as hell were not Kuhmo.
mark0006
Dec 25, 2014 09:50 PM
