If/when we get a supercharged Solstice
Old Feb 12, 2004 | 10:07 AM
  #16
slt's Avatar
slt
Originally posted by morb|d
the thing with the turbos is, there isn't a cheap way to get more power out of them once they're on the engine. with a S/C all you have to do is a pully swap to eek out some extra power. that's what, $5? $10?
or maybe i don't know enough about turbos, so somebody can clue me in.
Turbos are cheap to get power out of. Many see a 20hp gain just from a $40 boost controller which I guess is the turbo equivilent to putting on a bigger pulley. My G/F's GTI saw a 45hp gain from a $300 chip. My car saw a 50+ whp gain from a chip and a catback. A set of cams are worth 25-40hp depending on how aggressive you go. A down pipe would be worth another 10hp on either car.
The big potential comes from the fact that your car comes from the factory already set up for a turbo aplication with the oil squirters, stronger internals, lower compression, ect. An aftermarket turbo kit will cost $2500- $3500 and will let you run 350- 450 hp on stock internals. Beef those up and you can run 5-600hp.
Two big benifits of turbo over supercharging.
1. Free power
2. Full boost from spool up untill redline.
Old Feb 12, 2004 | 02:27 PM
  #17
96_Camaro_B4C's Avatar
Six Words: Don't count the turbo out yet
Old Feb 12, 2004 | 02:49 PM
  #18
IREngineer's Avatar
Four words: Listen to this man!
Old Feb 12, 2004 | 03:19 PM
  #19
RiceEating5.0's Avatar
1. Free power
Technically speaking, turbo's don't produce "free hp" since they create additional backpressure. While the loss isn't as big as a belt driven S/c'er, it is there.
Old Feb 12, 2004 | 03:49 PM
  #20
guionM's Avatar
Though I'm a devout fan of supercharging, I gotta say a Turbo Solstice is intriguing.
Old Feb 12, 2004 | 04:15 PM
  #21
slt's Avatar
slt
Thats right GM, Do what I command
Old Feb 12, 2004 | 06:39 PM
  #22
IREngineer's Avatar
What GM brand already has, or has shown in a concept, a turbo ecotech? Also, was there ever rumors of this same brand getting a kappa vehicle?
Things that make you go hmmm....
Old Feb 12, 2004 | 06:52 PM
  #23
uluz28's Avatar
Doh!
Old Feb 12, 2004 | 07:34 PM
  #24
Z28x's Avatar
Nomad had a 250HP Turbo VVT 2.2L Ecotec
Curve has a 230HP S/C VVT 2.2L Ecotec
I hope the GXP Solstice gets the Turbo VVT 2.2L
Old Feb 12, 2004 | 08:09 PM
  #25
newby's Avatar
Yah, there's lots of ways to increase HP for cheap on a turbo. You can buy a manual boost controller for 10 bucks to up the boost, same effect as swapping a pulley (without the danger of over-spinning the SC at redline. I don't think the Ecotec has a high enough redline for that to be an issue though.). Also, on a turbo exhaust mods add LOTS of power, moreso than on an NA car or a SC'd car usually. The more airflow out the back, the quicker the turbo can spool and the more boost it can make.
Old Feb 13, 2004 | 11:48 PM
  #26
guess who's Avatar
I know the Solstice starts @ $19,999.But whats its high range in price?26K?
Old Feb 14, 2004 | 12:16 AM
  #27
90rocz's Avatar
They're the closest thing to free power you'll see...and the power is theoretically infinite, if the engine holds together...where as a SC is driven off of the crank or rpm driven, the boost will eventially die off as rpm's do, the turbo driven by gases can keep going..and the higher the turbo spins(excess of 120K-rpms)the less of a restriction it becomes..
Smaller Modern turbo's have very little lag, so that argument won't hold water anymore...
I have an S/C car, and have owned 2 turbo cars, the 2 turbo 4cyl's would run with my current S/C 6cyl with little modding, I garantee..
For street manners, the SC wins, for performance the turbo wins..
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
