How to get 500+hp out of a LS1?
You can get lift and duration changes in real time by a solenoid operated pivot othe rocker arms. Move to a shaft mounted rocker arm and then you can control all the rockers on one shaft with one solenoid.You can also have a "dual cam profile" by a pin in the lifer that retracts at a certain rpm alowwing the lifter to sit on a different lobe profile. Add to this a larger bore block/ better flowing head, Veriable runner length, factory "rev kit" for higher RPM use, direct chamber fuel injection.. ect... I dont see why a 6.0 to 6.6L Pushrod motor couldnt make 500hp with ease. A 2 valve heart shape comb. chamber is better for fuel economy than a pentroof chamber so emissions wont be a problem.
Originally posted by guess who
Yes a solinoid (sp?) for each valve just like in F1.No cam at all.
Originally posted by R377
Are you saying F1 cars have no cams? I don't think that's the case. There's rumours of one of the cars running electromagenetic solenoids, but it's not likely due to the weight, complexity, power consumption, and inaccuracy.
Think Mercedez.....They dont have camshafts.They use electromagenetic solenoids.That is one i know for sure,As for everyone else Im not 100% certain on.
Originally posted by 99SilverSS
Doesn't BMW Williams have pneumatic (sp) valves for its F1 cars??
