Is GM beating Honda at it's own game with the supercharged Ecotech?
Old Jul 8, 2003 | 10:49 PM
  #46
R377's Avatar
Originally posted by Evil Turbo SS
How do you figure the S2000 has a higher VE. Displacement has nothing to do with the formula for VE. Simple how much air and fuel does a motor need to make its power. The honda uses more fuel and air per HP it makes. It is the loser.
I believe Mr. Bryant was suggesting the S2000 has higher VE based on its peak torque rating (torque is independent of rpm and is a pretty good barometer of volumetric efficiency). Divide its peak torque into its displacement, and do the same for the LS6, and the Honda makes a bit more torque which indicates it's filling its cylinders better.
VE does not measure "how much air and fuel does a motor need to make its power." Power does not figure into the equation at all (that's more the domain of thermodynamic efficiency). VE is a measure of how much air an engine intakes at a give rpm in relation to its displacement.
Hal Fisher
Sep 30, 2015 09:03 PM
NewsBot
Sep 30, 2015 04:20 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
