Fuel Cell Breakthrough?
Old Mar 31, 2011 | 11:47 AM
ADV1's Avatar
http://www.kfab.com/cc-common/news/s...ml?feed=104774.
CLEVELAND, March 22 (UPI) -- U.S. researchers say they've made a breakthrough in the development of low-cost hydrogen fuel cells that one day could power electric cars.
Researchers at Case Western Reserve University in Cleveland say catalysts made of carbon nanotubes dipped in a polymer solution can outperform traditional platinum catalysts in fuel cells at a fraction of the cost.
The scientists say the new technology can remove one of the biggest roadblocks to widespread cell use: the cost of the catalysts.
Platinum, which represents at least a quarter of the cost of fuel cells, currently sells for about $30,000 per pound, while the activated carbon nanotubes cost about $45 per pound, a Case release said Tuesday.
"This is a breakthrough," Liming Dai, a professor of chemical engineering and the research team leader, said.
Soaking carbon nanotubes in a water solution of the polymer for a couple of hours coats the nanotube surface and pulls an electron partially from the carbon, creating a net positive charge, researchers said.
When placed on the cathode of an alkaline fuel cell, the charged material acts as a catalyst for the oxygen-reduction reaction that produces electricity by electrochemically combining hydrogen and oxygen.
In testing, the researchers' carbon catalyst fuel cell produced as much power as an identical cell using a platinum catalyst.
Dai said he's confident his lab can increase the energy output of the new process.
"We have not optimized the system yet," he said.
One widely researched use for such cells would be to produce electricity to power an electric car, using hydrogen and oxygen from the air. The only emission from such a vehicle, researchers say, would be water.
Old Mar 31, 2011 | 11:49 AM
ADV1's Avatar
Re: Fuel Cell Breakthrough?
Here's a better link for you...
http://www.upi.com/Science_News/2011...3011300832974/
Old Mar 31, 2011 | 12:03 PM
Geoff Chadwick's Avatar
Is there anything carbon nanotubes CAN'T improve?
I'm excited. Conceptually, Fuel cells are superior to batteries any day of the week. I'm curious about what other rare earth elements are used in this new fuel cell design - fuel cells might end up becoming cheaper and easier to manufacture than batteries depending on the other metals used.
Old Mar 31, 2011 | 07:56 PM
Slappy3243's Avatar
http://www.dailytech.com/article.aspx?newsid=21270
New Device Uses Carbon Nanotubes to Catch Tumor Cells Quickly
Could eventually allow doctors to see if cancer has spread from its original site faster than ever
Harvard and MIT researchers have developed a tool that is capable of identifying single cancer cells within a blood sample.
Mehmet Toner, study leader and a professor of biomedical engineering at Harvard Medical School, and Brian Wardle, an MIT associate professor of aeronautics and astronautics, have created an instrument that could eventually allow doctors to see if cancer has spread from its original site faster than ever.
Circulating tumor cells, which are cancer cells that escaped from the original tumor, can be difficult to find because a 1-milliliter sample of blood, which has tens of billions of normal blood cells, only contains "several" circulating tumor cells.
"Of all deaths from cancer, 90 percent are not the result of cancer at the primary site," said Wardle. "They're from tumors that spread from the original site."
In response to this dilemma, Toner created a new microfluidic device capable of detecting these circulating tumor cells. He originally designed the device four years ago, and it worked by allowing a patient's blood sample to travel past tens of thousands of little silicon posts that are covered with antibodies. These antibodies stick to tumor cells, and any cancer cells that touch the silicon posts are caught and held in place. The problem with this prototype was that certain cells might never come in contact with the silicon posts at all.
Toner has since made changes to the device with the help of Wardle, making it eight times better than the original. The microfluidic device now features porous posts instead of those that are solid, which were made using carbon nanotubes. The carbon nanotubes are small, hollow cylinders that have walls made of carbon atom lattices. A "forest" of these nanotubes have 10 billion to 100 billion carbon nanotubes per square centimeter, and are 99 percent air and less than 1 percent carbon.
Much like the original version, these carbon nanotubes are coated with antibodies that capture particular cancer cells. The device is also customizable, allowing researchers to attach different antibodies to the carbon nanotubes or adjusting the space between the nanotubes in order to catch objects of different sizes, from circulating tumor cells to viruses.
The porous posts allow cells to run through them, much like a filter, offering greater chance of catching the cells researchers are looking for.
Toner and Wardle's device is currently being tested in hospitals and is expected to be made available commercially "within the next few years." In addition, researchers hope to adjust the device for HIV diagnosis as well.
I came across this article today. Nanotubes rock!
DirtyDaveW
Dec 1, 2016 05:37 PM
NewsBot
May 16, 2015 04:00 PM
cmyname1
Feb 19, 2015 08:38 PM
BLOWNBIRD
May 28, 2003 01:02 AM
BIGCOWL-IMP
Jul 22, 2002 04:26 PM
