Ford engine developements. Ford guys get in here.
Got this off of SVTperformance forums. It was posted today.
Additional Boss Engine Info:
As of right now, this is an iron block, with plans for an Al version. The Fe block weighs 211 pounds and will definitely be used in the F series. It has 102 mm (4.015") bores on 115 mm spacing. It does NOT have siamese cylinders. It DOES have piston squirters. The main journals are ~ 75 mm diameter and the bulkheads are pretty thick.
As for bore/sroke that's approx. 4.015"x3.49" for the 5.8, and 4.015"x3.73" for the 6.2.
Pressumably, unless there is room for a killer stroke too, I think it is supposed to have oil squirters for the pistons (dont see how that'll help emmissions??) but they are very handy when it comes to cooling down the piston for super-charged apps (and probably N/A high compression I would think).
The 351 Cleveland had smaller mains, and alot of Ford racing stuff used the 351 Windsor style block with the 351 Cleveland main bearing size. This was common practice on Nascrap stuff. Regular 351 Windsors have been used in drag racing at 8,000 RPM+, I dont see a big issue here.
The problem is that you get a lot of weight in the crank with the big bearings and you get a lot of heat in the bearings. If larger mains were better, than the LSx motors would be running them, but their not. Sure you can turn a 351w 8k rpms, but a 351c, with the smaller mains, will put less heat in the mains and be more relable.
Ford's heavy duty 351 siamesed bore blocks with a smaller (4.380) bore spacing can achieve a 4.125 x 4.250 stroke for comparison (and they even have small blocks capable of a 4.180" bore). Taken to an extreme using a 4.180 x 4.250 stroke, your talking 466 cubic inches. Granted, this is all supposition, but what I'm trying to say is, I'm pretty sure Ford, just didn't say; "Man we got alot of spare 2.95" bearings and alot cast iron/steel laying around, lets use it up on this new Boss engine"
--->edit<---
Also note, that even though it is old nascrap technology, the boss 429 used 3" mains.
Displacement is the ultimate trump card on N/A engines, If Ford designs a killer 2v (or 3/4v) head taking advantage of the OHC configuration (VVT, better port placement/shape) The engine should be pretty kick-****.
But I would expect them to use smaller bearings, unless they are not planning on reving these motors over 6k rpms. With a OHC engine, I just don't see the advantage of large diameter main journals. I'm sure this wasn't just thrown together from spare parts, but I guess I just don't understand why the use of such large journals. These BOSS motors just sound like what the 351W was, a low rpm truck motor.
Maybe I'm just reading it wrong and only the truck motors will have the 75mm mains, just some thought. One this is for sure, it shouldn't take much to make power with these motors.
The 3" bearing engines can be safely revved to 8,000 rpm, which is about 1750 rpm higher than Ford's traditional rev limit on most street engines. Besides, the OHC configuration has some nice advantages compared to an OHV configuration (a couple of which I mentioned in my edited post) including less valvetrain stress, potentially allowing the engine to use a more aggressive cam profile (however I suspect long life and durability take precedent over maximum performance), OHC really isn't all about screaming RPM. The downside to it just seems to be one of physical size and in the case of the Mustang, as long as the engine is dimensionally smaller than a S/C 5.4 4v DHOC V8 it doesn't really matter.
