Drove a LS2 SSR
Old Oct 18, 2004 | 09:24 AM
toneloc12345's Avatar
Drove a LS2 SSR
It doesn't really count though cause i just checked it in off the trailer and drove it into the dealership. I might have drove it a little longer if i knew it was a LS2 It says 390hp on the sticker. It sounds pretty good
TONY
Old Oct 18, 2004 | 10:29 AM
Mervz's Avatar
Re: Drove a LS2 SSR
well, wait untill you get to try the 6-speed with that motor, its awesome!!
Old Oct 18, 2004 | 02:15 PM
Gold_Rush's Avatar
Re: Drove a LS2 SSR
Any guesses on whether it'll be as quick as the 99-04 gen Lightning?
Whatever happened to the Silverado SS btw? Haven't heard anything on it in a while. Any plans to transplant the ls2 and 6spd combo into them as well?
Old Oct 19, 2004 | 11:11 PM
94LightningGal's Avatar
Re: Drove a LS2 SSR
Since it weighs as much as the Gen II Lightning, and has significantly less torque, I wouldn't think it would be as quick. 01+ Lightnings typically dyno around 350-360rwhp and 410-420rwtq. The Lightning weighs 4670lbs.
I guess you can use that as a basis of comparison.
Hope that helps.
Old Oct 19, 2004 | 11:37 PM
Meccadeth's Avatar
Re: Drove a LS2 SSR
I still think the SSR will be able to be faster than the Lightning...maybe not as quick in the 1/4, but I KNOW the SSR has less drag and frontal area than the Lightning.
What are the gear ratio's like for each car? That matters as much as anything.
Old Oct 20, 2004 | 12:20 AM
Re: Drove a LS2 SSR
The Lightning has 3.73 gears from '01+ and 3.55's from 99-00. I have no clue what the SSR has.
The biggest thing is, torque moves mass. Frontal area only becomes an issue at higher speeds. High torque is what moves fat as*ed vehicles like the Lightning and the SSR.
The high torque output of the L is part of the reason why it is so close to the Ram SRT-10 in the quarter........... despite having 120 less hp. While the Ram is 480lbs heavier than the Lightning, its rwtq is only about 40lb ft higher than the Lightning. Yet, 1/4 mile times show them to be around .2-.3 different.
Look at the C6 Vette, with the LS2. 3300lbs and 12.7 in the quarter. The SSR weighs 1400lbs more.
I'm not saying it won't be as fast.......... just that I don't see it.
Old Oct 20, 2004 | 01:02 AM
Meccadeth's Avatar
Re: Drove a LS2 SSR
I'm not saying that the SSR should be quicker than the Lightning (unless its insanely geared, which I doubt once gas milage is put into consideration), but it should be faster (top speed) than the Lightning. I agree 100% on the torque thing though.
Old Oct 20, 2004 | 10:07 AM
Z28x's Avatar
Re: Drove a LS2 SSR
will the 6 speed SSR be faster (top speed) than the RAM-SRT10? it has the aerodynamic advantage.
A limited edition fixed roof that is a few hundred pounds lighter and few thousand $ cheaper that is also faster than the SRT-10 would be a great way to bring some cheap positive press to the SSR.
Old Oct 20, 2004 | 10:12 AM
Re: Drove a LS2 SSR
the SSR we have at work has 3.73's in it
TONY
Old Oct 20, 2004 | 10:21 AM
Gold_Rush's Avatar
Re: Drove a LS2 SSR
It might be faster uptop, but i was thinking more along the lines of 1/4 mile. I don't expect it to run mid 13's like the L's, but anything slower than high 13's would be kind of a dissapointment imo considering the hefty price. Still, it is a big improvement over the previous 300hp 5.3 version.
Any news on the possiblity of the Silverado SS getting a sub-400hp Ls2 and a T56 as well?
Old Oct 20, 2004 | 12:31 PM
Re: Drove a LS2 SSR
Just to let you know, the top speed of the L is 147mph, and the Ram SRT-10 is 155mph.
A question though, what tires are they putting on the SSR's??? This will determine whether or not they limit the top speed.
Also, to let you know, the standard cab Ram SRT-10 weighs 5150lbs.
As for the Silverado SS.......... who knows. GM doesn't seem to know what they want to do with those. Also, they weigh as much as the Ram SRT-10 (around 5200lbs) in current form, so I don't know if they would put the manual in them. A manual would pretty much eliminate the towing capacity, which is one of the bragging points of the Silverado SS. The clutch in the Ram is a major weak point............ and the combination of the T56 with that clutch are the reasons the Ram has ZERO towing capacity.
Just some food for thought.
Old Oct 20, 2004 | 01:09 PM
Big Als Z's Avatar
Re: Drove a LS2 SSR
News is that Silverado will get the same LS2/6spd combo as will the Tblazer.
Old Oct 21, 2004 | 12:46 AM
indieaz's Avatar
Re: Drove a LS2 SSR
Man i had no idea the SSR was that heavy? How on earth did GM manage to build a 2-seater that weighs like 900 pounds more than 5-seater a GTO?
Old Oct 21, 2004 | 01:49 AM
Big Als Z's Avatar
Re: Drove a LS2 SSR
Well, lets see..
First off, the GTO is 3700lbs. Adding 900lbs to that doesnt get me 5k...it gets me 4600lbs.
Next, its built of a much stronger truck chassis.
Add on a hard top vert with all its mechanicals, as well as the sheetmetal which is very extensive and very sexy IMO.
Throw in some more creature comforts that go along with a 45k roadster...wham.
And the GTO is a 4seater.
Old Oct 21, 2004 | 07:36 AM
Meccadeth's Avatar
Re: Drove a LS2 SSR
The SSR doesn't have as many creature comforts as the GTO
But yea, that hard top 'vert and the chassis are what make the SSR a pig. But a very sexy pig
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
