Dohc V8
Get yourself a used Caddy ETC, they can be had for pretty cheap. The interior fit and finish usually isn't that great in the ETC, but the 300hp Northstar is a sweet pkg. They sound awesome and make good torque too. The aftermarket is starting to pick up for the Northstar V8, I've seen cat-back exhaust systems that give the Northstar an extra 20 hp, or so they say/advertise. I bet the stock intake is probably pretty restritive too, so you could slap on a CAI for starters.
The engine is gaining populuaraity with hot-rodders too, I've seen numerous little hot rods with Northstars in then setup for rear-wheel drive over the last few years.
Just imagine the Northstar with supercharger, in the right car. Can we say Cobra killer.
There was a guy who swapped a northstar into his V6 Camaro, I don't know what happened to him.
Also check out www.chrfab.com
Originally posted by Dan Baldwin
Large-displacement V8s really want to be OHV cam-in-block. Consider the Ford DOHC 4.6 mod motor and GM did the LS1 V8. The OHV LS1 is smaller, lighter, has a much lower c.g., allows for a much lower hoodline, makes more power, and (I'd bet anything) is cheaper.
Ford had to give the hood a bulge just to fit in!
Give me a OHV anyday
Z28x
15
Dec 16, 2004 08:30 PM
