6th gen Camaro, can it do 13.99 and get 34mpg?
Hey, can't have everything, dude. Besides, for a diesel V6, it's weight isn't bad at all.
As with most turbo diesels, I'd imagine it's tunability would be phenominal.
Also, it could share drivetrain (trans, clutch, axles, diff, etc.), development costs with the smallblock powered Z/28,
Diesel might be the best answer. The current BMW 335d will do 0-60 in 5.3sec, 0-100 in 13.4sec, and the 1/4 mile in 13.8sec. Best of all, it's rated at 36mpghwy. And this is in a car loaded with options with a test weight of 3,960lbs so far from a stripped light-weight.
http://www.roadandtrack.com/assets/d..._compchart.pdf
So it's very possible.
I dont see why not?
You have the current Camaro V6 gets an EPA 29mpg and hits the 1/4 in 14.2 @ 100mph! 100mph is a solid 13 sec car. My 87 runs 14.3 @ 96, so another 4mph faster is an easy 13 sec car.
Cut 300lbs off the car, add in more aerodymaic aids compared to the first gen brick nose, I dont see why not using existing technology.
Diesels are kind of cheating
I say that, because in the future, I expect CO2 to be what's regulated, and not MPG. Either that, or they'll have "gasoline-equivalent" MPG. Diesels emit quite a bit more CO2 per gallon burned.
You definitely get into the laws of diminishing returns past about 6 gears. Think about a CVT, which basically has an infinite number of ratios, and they don't really outperform a good 6-speed.
To pick up on your LNF example, the Solstice GXP weighs just shy of 3000 pounds, gets 28 mpg highway, and does the quarter in low-mid 14s. Figure on the F6 adding at least 400 pounds over a Kappa and you're already looking at high 14s (each 100 pounds adds about a tenth to your times). So you'd need the next-gen LNF to shave almost a second off its current capabilities, plus add 6 mpg in a heavier car. Seems like a tall order.
We also have 5-6 years or so for engine and transmission tech to improve. Just look at how much has improved since 2004 cars.
.Thread
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Dec 7, 2014 11:32 AM
