3 valve V10 coming from Ford next year.
Old May 24, 2004 | 11:55 AM
Z28x's Avatar
http://www.detnews.com/2004/autosins...a04-161700.htm
The 2005 Super Duty can be equipped with a 5.4-liter Triton V-8 engine or 6.8-liter Triton V-10 — each featuring three valves per cylinder rather than four, which improves fuel efficiency without compromising power.
Old May 24, 2004 | 11:57 AM
RiceEating5.0's Avatar
I figured the 6.8L v10 would get the 3valve treatment as well. I wonder what the output will be.
Old May 24, 2004 | 03:57 PM
morb|d's Avatar
this is funny, because Mercedes, once the stalwart of 3 valve engines has recently began a push to convert their engines to DOHC 4 valvers all the while Ford is doing the opposite.
Old May 24, 2004 | 05:13 PM
HAZ-Matt's Avatar
So what are the advantages of three valves over four? Why would it give you better fuel economy? Are the three valve motors SOHC and so benefit from two less cams?
Old May 24, 2004 | 09:16 PM
305fan's Avatar
Actually--Mercedes was 4 THEN 3 and now going back to 4 valves per cly. I think cost was sighted going from 4-3.
Fords V-10 has been a pretty gutless motor. I have a test of 3/4 ton GM 6.0 and 3/4 ton Fod 6.8L V10---it gets smoked.
Heres hoping GM pumps up the 8.1L!
Old May 24, 2004 | 09:20 PM
number77's Avatar
yea, these truck wars as of late are a bit interesting. i wonder how well they fit in cars. if i had the money, i think i would experiment.
Old May 24, 2004 | 09:38 PM
Yeah, 3valve motors are usually Sohc. I guess you get a lighter, cheaper, and more compact motor in the end (sohc vs dohc).
From what i've gathered, the 3valve heads on the GT flow as well (or near as well) as the 4valve heads in the Cobra's and Mach 1's. So airflow is improved due to the 2 intake valves in comparison to the 2valve heads 1 intake valve.
Here's a readup on the 5.4L 3valve motor. They talk about a few of the benifits of 3 valve heads.
http://www.ford-trucks.com/news/newsh3.html
Old May 24, 2004 | 10:39 PM
Derek M's Avatar
How bout 355HP/455TQ for the Ford 3 valve V10....
Couple of items I came across on another board....
http://www.ford-trucks.com/specs/200...uty_Specs2.pdf
Old May 25, 2004 | 01:17 PM
ced8's Avatar
Just thought I would add this link to the thread. It also has some pics of the 05 Super Duty (ala TONKA Concept)
http://www.pickuptruck.com/html/news...uperduty1.html
Old May 25, 2004 | 02:37 PM
IREngineer's Avatar
You wanna talk about a big, almost intimidating pickup. You walk up to it and you want to search for the Mack hood ornament. I consider it very much like the first time I saw the Ram after its 90's redesign.
Old May 25, 2004 | 07:52 PM
ImportedRoomate's Avatar
Well ford is now at the bottom of the diesel wars with 570 torque. GM has 590 and Dodge is at 600.
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
ChrisFrez
Dec 15, 2014 03:09 PM
NewsBot
Dec 3, 2014 12:30 PM
