2014 XTS to get 410HP TT V6
Old May 15, 2013 | 08:49 AM
Z28x's Avatar
2014 Cadillac XTS gets 410-hp twin-turbo V6
Hmm... now that we know an Epsilon II based vehicle can handle that much power, I wonder if there is any chance of this engine going into a Buick Regal.
Old May 15, 2013 | 03:05 PM
TQdrivenws6's Avatar
Re: 2014 XTS to get 410HP TT V6
Losing 10hp isn't a huge deal, the 61ft-lbs of torque is quite the reduction though. Probably still a nice powertrain for the application.
What are the odds that this will come with AWD as an option? I could see torque steer being an issue in FWD but AWD should take care of that.
Old May 15, 2013 | 10:00 PM
ImportedRoomate's Avatar
AWD is standard with the TTV6. Its not available with FWD.
Old May 15, 2013 | 10:03 PM
Or if it weren't for the SS sedan, an Impala SS to go up against the SHO.
Old May 15, 2013 | 10:04 PM
King Moose SS's Avatar
FWD drive cars have had a bad history with high HP and torque ratings. The transmissions have been a known weak spot. GM had issues with the LS4 in the Impala SS and Grand Prix GXP, and they produced well under this TT V6's power.
Edit: Now I see it's only available with AWD, not sure if that solves the problem, but I'm sure there's a reliability reason why GM didn't offer FWD with this engine.
Old May 16, 2013 | 07:04 PM
muckz's Avatar
Technically, if you can make AWD reliable, the same car with FWD should be just as reliable (assuming both use transversely mounted or longitudinally mounted engines/transmissions).
I think it has more to do with having so much power at the front wheels (hello torque steer, and traction control) than reliability.
Old May 18, 2013 | 12:21 PM
30thZ286speed's Avatar
It will be interesting to see what other applications can benefit from LF3. I guess this setup in the XTS is not enough to be a XTS-V.
Old May 20, 2013 | 12:00 PM
colin911's Avatar
Never be late for bingo again!
themex2002
Sep 2, 2015 03:47 PM
WPHIG2
Aug 27, 2015 06:37 AM
meissen
Aug 11, 2015 06:05 AM
ImportedRoomate
May 23, 2012 03:34 PM
95redLT1
18
Jul 13, 2010 08:37 AM
