2011 Chevrolet Cruze Eco rated at 42 mpg highway
Old Nov 11, 2010 | 03:19 PM
95redLT1's Avatar
General Motors has released official fuel economy numbers for the 2011 Chevrolet Cruze Eco, and the automaker's original target of 40 miles per gallon (highway) has been surpassed. The Cruze Eco is officially rated at 28/42 mpg with the six-speed manual transmission, making it the segment-leader in terms of efficiency.
To achieve this, the Eco uses GM's latest 1.4-liter turbocharged inline-four, rated at 138 horsepower and 148 pound-feet of torque. On its own, the engine is efficient enough to deliver 24/36 mpg, but a host of aerodynamic changes and weight reductions on the Eco account for the extra bump in fuel economy. In addition to a lower front air dam extension, rear spoiler, lowered ride height and revised underbody panels, the Cruze Eco rides on lightweight 17-inch alloy wheels wrapped in low-rolling-resistance tires. What's more, a front grille shutter has been developed to improve airflow at higher speeds, thus accounting for a 10 percent coefficient of drag over standard Cruze models.
The Cruze Eco is priced from $18,895 and hits dealerships in January of next year. For the full details, hit the jump for GM's press blast.
http://www.autoblog.com/2010/11/11/2...2-mpg-highway/
Old Nov 11, 2010 | 03:23 PM
96_Camaro_B4C's Avatar
Re: 2011 Chevrolet Cruze Eco rated at 42 mpg highway
Excellent!
95redLT1's Avatar
Press release:
DETROIT – The official fuel economy numbers for the 2011 Chevrolet Cruze Eco are in and they’re good. Segment-leading good. It delivers an EPA-estimated 42 mpg on the highway (manual transmission models), with equally impressive city fuel economy of 28 mpg.
Cruze Eco’s highway fuel economy beats non-hybrid segment competitors – including 23 percent greater highway fuel economy than the Honda Civic – as well as the Ford Fiesta subcompact and many hybrid models. In fact, it’s better than Ford Fusion Hybrid, Nissan Altima Hybrid and Toyota Camry Hybrid.
“Chevrolet Cruze continues to redefine the compact segment, offering class-leading standard safety features, upscale amenities – as well as hybrid-like fuel economy without the price,” said Chuck Russell, vehicle line director. “The Cruze Eco is in a league of its own and will challenge perceptions of the efficiency available in a more affordable non-hybrid.”
The Cruze Eco carries an MSRP of $18,895 (including destination charge). It goes on sale in January.
To achieve its segment-leading fuel economy, Cruze’s engineers focused on aerodynamic performance, mass optimization and powertrain enhancements. The refinements in each area paid big dividends towards the car’s overall efficiency, while providing engineers with valuable information to help enhance the efficiency of future Chevrolet models.
“We left no stone unturned or piece of sheet metal un-weighed,” said Russell. “Our engineers were comprehensive and thorough when it came to evaluating and modifying the aspects of the car’s performance that contribute to fuel economy.”
Aero enhancements
Aerodynamic improvements over non-Eco manual-transmission models contributed approximately six mpg to the Cruze’s EPA-estimated 42 mpg highway fuel economy. Many were developed and refined in more than 500 hours of wind-tunnel testing of the Chevy Volt, which shares a core architecture with the Cruze. Examples include the upper grille, which has more “closeouts” to improve aerodynamics, a lower front air dam extension, a rear spoiler, a lowered ride height and underbody panels that smooth airflow beneath the car.
The Eco model also features an all-new technology in the compact segment: a lower front grille air shutter that closes at higher speeds to reduce aerodynamic drag and opens at lower speeds to optimize engine-cooling airflow. Another contributor to reduced drag is the use of ultra-low rolling resistance 17-inch Goodyear tires (used with lightweight wheels), which are also used on the Volt.
As a result of the aero enhancements, aerodynamic drag was reduced by 10 percent over a non-Eco model, with a coefficient of drag of 0.298. That places Cruze at the top of the class for mainstream compact cars.
Mass optimization
More than 42 changes were made on the Eco to reduce weight. It weighs in at 3,009 pounds (1,365 kg), compared to the 3,223 pounds (1,462 kg) of the Cruze 1LT. The diet program for the Cruze challenged engineers to look at all aspects of the vehicle’s construction, including hundreds of weld flanges on the vehicle. They were reduced 1 mm to 2 mm in length, which saved several pounds, while the sheet metal gauge thickness was reduced by about 0.1 mm in select components. This saved weight while preserving structural integrity.
Lighter wheels and tires are used on the Eco. They’re stylish, polished 17-inch alloy units with Goodyear tires that weigh only 36.5 pounds (16.6 kg) apiece. That’s 5.3 pounds (2.4 kg) less than the 16-inch wheel/tires of the Cruze 1LT for a complete savings to the vehicle of 21.2 pounds (9.6 kg).
Efficient powertrain
Cruze Eco is powered by power-dense Ecotec 1.4L turbocharged engine and a standard six-speed manual transmission. The transmission’s gearing is optimized for the model’s specific 17-inch wheel/tire combination and includes aggressive ratios for first and second gear coupled with a highly efficient, “taller” sixth-gear ratio for highway driving. That means engine rpm is reduced on the highway, which in turn reduces fuel consumption. A six-speed automatic transmission is available, with EPA-estimated fuel economy ratings of 26 city and 37 highway.
The Ecotec 1.4L turbo’s power ratings are 138 horsepower (103 kW) and 148 lb.-ft. of torque (200 Nm) between 1,850 rpm and 4,900 rpm. The wide rpm range for the maximum torque – a specific trait of turbocharged engines – helps the engine deliver a better driving experience and performance. The turbocharger is integrated within the exhaust manifold, for reduced weight and greater packaging flexibility.
The engine also features premium design elements that give it world-class smoothness and durability while also contributing to the Cruze Eco’s lower curb weight. They include a cast iron block with a hollow frame structure, hollow-cast camshafts and a plastic intake manifold.
Comparing the competitors
As a result of aerodynamic improvements, mass reduction and powertrain optimization, the Cruze Eco offers the best fuel economy in the compact segment, while delivering hybrid-like fuel economy without the hybrid price. The following charts show how it compares with primary competitors and popular hybrids.
Cruze Eco vs. segment competitors at the link...
http://media.gm.com/content/media/us...1111_cruze_eco
Old Nov 11, 2010 | 03:24 PM
Z28x's Avatar
Awesome, now that is more like it!
Old Nov 11, 2010 | 03:26 PM
Holy crap, they knocked 200 lbs off the car!
Get those guys (and the aero guys!) working on the Camaro...
Obviously the 5th gen can't switch to low rolling resistance tires and skinny wheels, but I'm sure lots of weight could be saved elsewhere.
Would be neat to see 30+ mpg for the V6, and a 3650 lb SS sounds much more delicious than a 3860 lb SS...
Old Nov 11, 2010 | 03:34 PM
soul strife's Avatar
Nice Job GM!
Old Nov 11, 2010 | 03:47 PM
msgZ28's Avatar
I hope some of that makes it to the regular Cruze too.
Old Nov 11, 2010 | 04:16 PM
HAZ-Matt's Avatar
Or more importantly, hopefully these techniques are incorporated in all the future platforms.
I'm interested to see a comparison of the gear ratios in the manual versus the automatic. Especially 6th gear... I wonder if this thing can pass at all in top gear.
Old Nov 12, 2010 | 08:47 AM
km9v's Avatar
The grill shutters, lowering & lower air dam are thing they can do to any vehicle. Imagine getting 2-4 MPG more on all pickups & SUVs.
Old Nov 12, 2010 | 10:53 AM
JeremyNYR's Avatar
I love posts like this! Way to go GM taking a logical approach to beating the heck out of the competition in MPGs! Who needs more weight with dual powertrains offered in hybrids when you can reduce the mass (especially rotating mass) and make the whole package more efficient??!!
I hope their marketing team is able to effectively inform people that a Chevy without the complexity and maintenance cost of a hybrid soundly beats the competition in fuel economy.
Old Nov 12, 2010 | 12:10 PM
Threxx's Avatar
This just in:
Almost nobody cares about manual transmission MPG.
The auto is rated at 26/37, and that's not bad, but that's what people are going to be looking at when they consider whether they should buy a Corolla, Civic or Cruze.
As an aside... I wonder if they stripped any sound deadening out to drop the 200 pounds?
Old Nov 12, 2010 | 12:17 PM
Originally Posted by Threxx
This just in:
I do agree with you on the surface, however, you have to remember that Chevy has a hard time getting brandhuggers to just look at their cars. So, when a comercial comes across and says 42MPG (small print: with a stick), it will drive in some conquest traffic. At least that's the hope.
Old Nov 12, 2010 | 12:46 PM
94LightningGal's Avatar
Ahhh, so bait and switch. That will make customers all warm and fuzzy.
Exaggerating a bit. Getting them in the door is the important part.
As for sound deadening, yes, they did cut down on it. However, the MT guys say that even with less sound deadening, it is no noisier than a Corolla.
The biggest deal, to me, is the change of the rear suspension............. from the Watts Link, to the cheap beam. That should really affect the feel of the car.
Old Nov 12, 2010 | 01:29 PM
Z28x's Avatar
Isn't that the way it is for every car. They always advertise the model with highest MPG, HP, 0-60, etc...
Remember the latest Ford Mustang commercial with advertising 31MPG yet showing the manual trans car that only gets 29mpg.
http://www.youtube.com/watch?v=Gh4HE9bNHK4
Old Nov 12, 2010 | 02:03 PM
JeremyNYR's Avatar
We can get really picky about it. If you were looking for a real world MPG figure, many people would experience closer to the city mpg than the highway number too. But we all know that marketing will use the best sounding number that it can without outright lying.
