2011 Cadillac CTS Coupe debuts
Old Nov 23, 2009 | 08:58 AM
95redLT1's Avatar
LOS ANGELES – Cadillac today unveiled the 2011 CTS Coupe, the latest and most dramatic of the brand’s series of new designs to reach production. Slated to arrive in Cadillac showrooms in the spring of 2010, the CTS Coupe is a new luxury sports coupe designed to become the centerpiece of the brand’s revised lineup.
“CTS Coupe is the new focal point of Cadillac, expressing both our design and technical capabilities,” said Bryan Nesbitt, Cadillac general manager. “It is intended to appeal to a new generation of car enthusiasts.”
The Coupe joins the CTS Sport Sedan, the 556-horsepower (415 kW) CTS-V and new CTS Sport Wagon as the foundation of Cadillac’s lineup. A high-performance V-Series edition of the Coupe will also be released in 2010.
The CTS Coupe’s design carries over virtually unchanged from the concept car that was introduced at the North American International Auto Show in Detroit in 2008.
The Coupe is a classic 2+2 layout bolstered with advanced technology, such as a rear-view camera system and a performance-oriented suspension system coupled to rear-wheel or all-wheel drive.
Design
CTS Coupe emerged as a proposal inside Cadillac’s design studio, where designers have developed and evolved the brand’s Art and Science design philosophy.
“Cadillac has always been an emotional brand – it’s about delivering art regardless of body style,” said Max Wolff, director of exterior design for Cadillac. “With the CTS Coupe, it was about taking something very strong – the CTS Sport Sedan – and extending its potential.”
The coupe has the same wheelbase as the CTS, but an overall height that is approximately two inches (51 mm) lower and an overall length that is two inches (51 mm) shorter.
Although it draws from its sport sedan sister, the CTS Coupe shares only the instrument panel, console, headlamps, front fenders and grille. Key design features include:
* Classic hardtop styling, with no conventional B-pillar
* Touch-pad operation for the doors removes the need for conventional door handles, creating a technical, clean profile
* A windshield laid at a faster angle (62.3 degrees) and a long, nearly horizontal backglass area combine to create a sleek, aerodynamic look
* Sculpted lower front fascia with unique brake-cooling vents
* Diamond cut-style rear fascia with mesh lower grilles
* Center-outlet exhaust with twin dihedral-shaped tips that pass through the rear fascia
* Signature vertical lighting, highlighted with LED light pipes
* Rear spoiler integrated into the center high-mounted stop lamp
* Sculpted roof-mounted antenna for OnStar and XM Satellite Radio.
At first glance, the shape of CTS Coupe is refreshingly simple, yet amplified with intricately carved details. Distinctive and original Cadillac signature cues combine with hand-sculpted forms, artfully articulating the confidence of the chassis. For example, the rear fenders were purposefully developed by hand in Cadillac design studios to visually acknowledge the RWD powertrain. The gestured profile, coupled with Cadillac’s vertical taillamps and pronounced rear centerline, aim to achieve the most visually confident coupe in the segment.
Performance
The CTS Coupe extends Cadillac’s emerging performance credentials. The CTS Coupe’s standard powertrain consists of a direct injected 3.6L V-6 and six-speed manual transmission. Direct injection technology delivers fuel more precisely to increase the efficiency of combustion, enabling more power while maintaining fuel economy and lowering emissions – including a 25-percent drop in cold-start hydrocarbon emissions.
The 3.6L DI engine is rated at 304 horsepower (227 kW) and offers EPA-estimated fuel economy of 27 mpg on the highway. It also runs on less expensive regular unleaded gasoline.
The powertrain’s performance is channeled through a chassis that delivers sports car performance without punishment. The hardware includes an independent short/long arm ( SLA) front suspension system, with hydraulic control arm front bushings; and a multi-link rear suspension mounted on a fully isolated subframe. Also included are four-wheel disc performance brakes, premium steering and limited-slip differential.
Two suspension-tuning levels are available: a Performance Package with 18-inch wheels and all-season tires (available in both RWD and AWD,) and the Summer Tire Performance Package, with 19-inch tires and wheels and a higher level of road holding capability. StabiliTrak, the advanced electronic chassis control system, is standard.
The 304-horsepower (227 kW) 3.6L V-6 Direct Injection engine will be standard, equipped with a six-speed manual, featuring a revised clutch and dual-mass flywheel that offers better clutch pedal feel and improved engine isolation. A 6-speed automatic transmission with Driver Shift Control (and available steering wheel mounted shift buttons) is optional.
Technology
CTS Coupe blends handcrafted luxury with a contemporary, driver-focused interior that supports the car’s high-performance capabilities. The interior includes hand-sewn accents covering the door, center storage console and instrument panel trim. 14-Way adjustable Recaro sport seats, previously exclusively offered on Cadillac’s V-Series model, will be offered on all CTS Coupe models as an option.
The car offers a host of advanced technologies, including:
* Integrated iPod/MP3 capability
* 40-gig hard drive, including the ability to store music and pause-and-replay live radio
* Pop-up navigation system
* Adaptive forward lighting system
* Bluetooth connectivity
* Standard Keyless Access and Smart Remote Start
* Rear Camera system
* Bose 5.1 Cabin Surround™ audio system
As with other Cadillac models, the CTS Coupe comes standard with OnStar with Turn-by-Turn Navigation, the first factory-installed, fully integrated GPS navigation system from OnStar.
http://media.gm.com/content/media/us...1123_CTS_Coupe
Specs & more pictures at the link
Old Nov 23, 2009 | 09:04 AM
Z28x's Avatar
That car is gorgeous. CTS-V coupe would be my dream car. I like what I see with the standard and optional features.
shock6906's Avatar
Cool. Being a two-door fan, this is a Cadillac I could see myself in.
Old Nov 23, 2009 | 09:25 AM
95redLT1's Avatar
Its hard to tell, are those the same wheels that were on the Leno TT Camaro?
Old Nov 23, 2009 | 09:45 AM
90 Z28SS's Avatar
Nope , there the 19" wheels current available on the CTS wagon . Hmmmm , no b-pillar , wonder if that back window goes down too .
Old Nov 23, 2009 | 09:59 AM
SmokeyZ's Avatar
Sweeet....
Old Nov 23, 2009 | 10:08 AM
jg95z28's Avatar
Originally Posted by 90 Z28SS
Hmmmm , no b-pillar...
Look again.
Now that we've seen the Leno Camaro, is anyone else thinking a TTV6 in the CTS Coupe would be an awesome combination?
Old Nov 23, 2009 | 10:16 AM
90 Z28SS's Avatar
Originally Posted by jg95z28
Look again.
I think it would be the perfect step in between the the base and CTS-v . I didnt get the b-pillar thing ....their wording states , no conventional b-billar , but in the pics it looks like ones there
Old Nov 23, 2009 | 10:44 AM
jg95z28's Avatar
I missed where it said "no conventional b-pillar" but like you said, it appears there is one in the photos. I may be mistaken on that.
Old Nov 23, 2009 | 10:51 AM
R377's Avatar
I thought they'd said the central exhaust that was on the concept wouldn't make it to production. Oh well, it shouldn't be a dealbreaker ...
Old Nov 23, 2009 | 10:55 AM
Aaron91RS's Avatar
lose the butthole exhaust
Old Nov 23, 2009 | 11:27 AM
Silverado C-10's Avatar
Now that's hot.
Old Nov 23, 2009 | 02:55 PM
1fastdog's Avatar
Actually, its a petty cool looking exhaust outlet IMO.
Old Nov 23, 2009 | 04:01 PM
96_Camaro_B4C's Avatar
Hot looking overall, but dang that is a lot of sheetmetal in the rear 1/4 panel area.
If we extrapolate from the current design trends, in about 5 years cars will have no side or back glass save for small, defensive gun slits. Visibility will be entirely dependent on cameras...
Speaking of which, I'm assuming this thing has a back up camera standard, because I bet the point at which you can see the ground through the rear glass is approaching infinity, even for taller drivers.
Love the powertrain though. And I agree that at TT version of this engine (a la Leno Camaro) would be PERFECT.
Old Nov 23, 2009 | 05:48 PM
1fastdog's Avatar
It looks really good in person.
