05 GT, M5 Dyno.
Re: 05 GT, M5 Dyno.
Cripes, let this die.
We'll know soon enough what it really runs on a regular basis at a track.
From the information we have so far, LS1 F-car vs. '05 GT = driver's race, with the GT taking the LS1 out of the hole (because of gearing) and the LS1 running it down up top (because of the power advantage).
Saying anything more or less than that is just stupid at this point.
Arguing about it is even dumber.
Re: 05 GT, M5 Dyno.
Originally Posted by The Highlander
20k cars because gm wanted to shut down the plant because it was getting old.. period.. the camaro was GOING to be killed one way or another... but yeah... lets compare it to an 05 GTO!!! 100HP Difference!!!!oopss.. IRS and i'm betting low 13s 1/4mile @ 10mph EASILY more. so there you have the difference...
Sorry but its not fair to compare an 05 car with a 95 car.. there are 10 years difference... the reality.. both new.. i choose the LT1 over that crappy 4.6
and why an lt1 over a 4.6? the 4.6 having 3 valves per cylinder has a greater chance at making better numbers on paper. the lt1 does make good numbers but i would rather have something smaller that makes better numbers.
Re: 05 GT, M5 Dyno.
SMALLER?
What planet are you on???
The only way the 4.6 is smaller than the LT1 is in displacement. Other than that the damed thing is a boat anchor. It's freaking HUGE.
Displacement means NOTHING unless you are racing in a displacement-limited class.
Re: 05 GT, M5 Dyno.
Thanks glovesperson... how about that ... 100rwhp more... even mod vs mod the ls2 is a far superior engine...
3valves per cylinder isn't much if it isn't making hte power.. i would have hoped that that engine would make more or less the same power as the ls2 since it has 50% more valves vs 30% more displacement???? that is following your logic...
The reality is that i bet the ls2 heads flow better than those 3 valve heads... in the end it proves that the head design from that 4.6 is totally crap if with more valves you can't do more flow than with 2v/cyl
as a matter of fact... i have a video where a SVT guy says.. "there is no way we could make the power we wanted out of the 4.6, so we forged it and strapped a supercharger to it."
Re: 05 GT, M5 Dyno.
Originally Posted by PacerX
God, here we go again...
SMALLER?
SMALLER?
Al, reading comprehension buddy. i was talking about the 05 GTO. i dont know of any that are out yet. but i could be wrong like i was with the dyno numbers.
Re: 05 GT, M5 Dyno.
Actually no... i prefer the bigger displacement engine making the same HP.. why?? because it will make more torque overall than the smaller engine... And you know... the more torque you get overall means you get more hp overall means you get to the top rpm range faster, which means accelerates faster.
if not... why don't you put a v6 DOHC honda engine on the Camaro since it had 270HP also... its a lot smaller... lets see how it pulls the camaro w/o the torque.. and it has 4valves and it has VTEC... sorry bud...
Re: 05 GT, M5 Dyno.
displacement determines powerband sometimes. a smaller engine will most likely have a longer powerband, something that makes a car faster than off idle torque.
In truth, due to the fact that larger displacement motors can provide adequate torque for driveability with far more radical cam timing events (and thereby wind out further), the situation is even WORSE for the smaller motor.
They can run bigger valves, more radical cams, better rocker setups, have higher flow heads (since displacement for a given design usually means that the cylinder heads themselves grow along with it... look at the heads on a small block Chevy vs. a big block Chevy some time...) all while maintaining better driveability and higher average power.
so i go back to my original statement. i would like a smaller displacement higher revving engine.
Anything you can do to a little motor, I can do to a big one - and get more out of it for less money.
Re: 05 GT, M5 Dyno.
Re: 05 GT, M5 Dyno.
Have you ever heard of "small man syndrome"? Its actually deamed a true psychological disorder. Maybe there should be a new disorder for the Ford Boys called "small engine syndrome"!
Re: 05 GT, M5 Dyno.
goes to show you how dyno numbers and track times really mean jack sh*t to most car buyers. i mean look at it, 20k fbodies total in 02? that REALLY looks like people cared that they ran good or dynoed high...
frankly, i can respect those numbers considering they came from a mustang dyno. still makes more than my turd gen did on a dynojet and for the time being will run faster than i will too. i guess some people on this site lack the tact to comprehend that.
02 Camaro total production = 42,098
http://www.ls2.com/forums/showthread...threadid=56795
02 Firebird total production = 30,690
http://www.ls2.com/forums/showthread...hreadid=113481
That's a total F-body production of 72,698. Not stellar by any means, but far removed from 20k. I honestly don't understand why people continue to dog the 4th gens by painting a bleaker picture than there was. I personally think 72k total production is pretty good considering all advertising had been pulled and the decision to kill it had been made 5 years earlier.
Re: 05 GT, M5 Dyno.
Originally Posted by Gloveperson
The LT1 sales were seriosly good against the mustang, especially since the mustang absolutly sucked back then. If GM didn't under-rate the LS1, I think a lot more people would have bought those, too.
-Todd
-Todd
Post #12 has the total F-body numbers against Mustang. Notice what happened in 97 before the bottom fell out of the F-body program.
Re: 05 GT, M5 Dyno.
Originally Posted by Z28Wilson
Mustang dyno, Dynojet dyno.....it isn't that impressive. For it to run with LS1s in stock form it is going to need some pretty stout gearing if this is more the norm...
It's interesting how MT goes 13.6@100 in a GT and we get posts saying with a simple tune the GT will break into the 12's, now we see a dyno result that relieves Chevy guys...how about we wait a few months and see these things in the hands of real drivers and see what they'll average. All this information is quite conflicting.
Re: 05 GT, M5 Dyno.
Originally Posted by Big Als Z
Its sad...but you know whats worse? When 3 years later, Ford with 3v heads, VVT, and all this "high tech" crap in there engine, still cant make numbers the Camaro and Firebird were doing back in 02....
Now thats sad. Anyone have 05 GTO numbers?
