Autocross and Road Racing Technique There is more to life than a straight line
Suspension material
Old Apr 28, 2003 | 07:14 PM
ru2slo_99's Avatar
Suspension material
Is 6061 T6 Aluminum a strong enough material to make suspension parts out of?
Old Apr 28, 2003 | 09:19 PM
Jon A's Avatar
The material isn't the only factor. Its thickness and geometry are just as important. You could make suspension parts out of balsa wood if you made them big enough.
That said, 3/4 of my rear suspension is made from 6061. What sort of part did you have in mind?
Old Apr 29, 2003 | 02:57 PM
ru2slo_99's Avatar
I was thinking of making my LCAs and pnahard rod. I have been looking aroind a little and with the price of rod ends so high, I can buy the LCAs for less then making them.
Old Apr 29, 2003 | 05:54 PM
Jon A's Avatar
Check out my Mods page in the sig.
Old Apr 30, 2003 | 06:25 PM
ru2slo_99's Avatar
That is a great website. I like how you documented everything with pictures.
Old Apr 30, 2003 | 09:37 PM
Jon A's Avatar
Thanks.
Take it from me as I learned the hard way: Any parts you can buy for less than you can make them for (using quality rod ends) will have completely crappy cheap rod ends that will soon rattle incesantly to the point of driving you nuts. After you replace the ends with quality ones, you've spent more money than just buying quality stuff in the first place.
If you want to buy rod-ended LCA's and PHB the only ones I know of that use quality rod ends are the LG Motorsports and Unbalanced Engineering pieces. They're expensive, but worth it. If you don't want to pay that much, make your own. The LCA's are only $12 each and the PHB is $20. All the money is in the rod ends.
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
TGGodfrey
Aug 17, 2015 08:43 PM
Aug 17, 2015 09:50 AM
