Autocross and Road Racing Technique There is more to life than a straight line
Susp help/ aligment questions. Answers needed quick.
Old Aug 30, 2002 | 03:55 AM
ZBLKHELLRZR's Avatar
Question Susp help/ aligment questions. Answers needed quick.
Anyone have a recommendation for street/auto-x/road?
GC coilovers 600#fr & 150#rr, revalved, bilsteins, upper and lower BMR front A-arms are going on in the morning. Sway bar on now are ST 35&25mm w/ the option of putting on the 21 which seems to be the choice for most.
She is mostly a a twice or 3 time a wk driver so tire wear isn't a concern for the most part. Drive hard in the corners here since the roads are mostly that and more challenging.
Initially I was thinking
-1 camber
0 toe
+3 caster
Now after reading some previous posts
-1.5 to -2 camber
0 toe still unless there is better option
+4.4 - +5 caster
Want to be able to still run high speeds here on the autobahn and feel stable yet kill 'em in the corners when need be.
Thanks for any help!
93Zm6 Blk TT stk 3.23's
Engine mods:
Balanced & Blue printed 396 Forged Lunati internals, Stage II Heads, Taylor wires, NGK TR55's, Accel 300+ & coil, 95+ opticrap, AS&M 58mm TB, ATI damper, AFR Rev Kit, FLP's & Borla exhaust w/top flight corvette cockpit exhaust adj, Metco AFPR, Accel 30lb inj, Ed Wright Chip, 160 stat, Hurst Pro Shifter,
Mcleod Street twin & alum fly, TPIS 3.5 DS, T/A Cover w/ stud kit
Susp mods: Flowtech adj. TA, KB SFC& 3 PT STB, Eibach sportline springs, Bilsteins shocks, Hotchkis PHR & LCA w/ Spohn LCAB, Poly tranny mount, Suspension tech sway bars 35&25mm, Baer bump steer rods, Baer Track system 13"F 11.7"R drilled/slotted/zinc plated, steel braided lines
Cosm mods:
Ultra Z hood(funtional)K&N, G2 5" rear spoiler & front Gfx, Rytek headlights(oval version),DGmotorsports carbon fiber dual foglights, G2 world challenge wheels 17x9.5 Pwdr coated BLK, Falken 45 ZR17's 275/40, RK smoke signal covers, fire ext, chrome throttle cover, chrome fuse box, chrome LT1 badges, carbon fiber emblem
Interior: Corbeau Targa RS seats & Harness, G2 Harness Bar, RK Wht face gauge, G2 pedals & door sills,
Auto Lite Oil, Tranny temp guage, & FP guage
Future mods: Upper & Lower A-Arms, coilovers, revalved bilsteins
http://community.webshots.com/album/40511381WqPSWB
Old Aug 30, 2002 | 10:34 AM
Dave K's Avatar
Post
Just had mine aligned today
-1.2 camber
0 toe
+4.5 caster
Not sure how it'll work out yet, but my main goal is to even out the front tire wear somewhat (normally I wear the outside edges LONG before the inside) and provide a bit of a handling boost.
Old Aug 30, 2002 | 11:24 AM
Compstall's Avatar
Post
I agree with Dave's specs. I installed poly bushings in my a-arms recently and made the big mistake of having everything put to stock specs (-0.5 camber). This sucks, and as I recall that caused my tires to wear excessively on the outer edges in the front. My car has HORRIBLE push now, and I need to take it back. Previously I had -1.1 camber with EVEN tire wear in the front.
- Brent
~Project 12's DAMMIT!~
'94 Z28, M6, Borla Y-pipe, Flowmaster Cat-Back, Lingenfelter CAI, MSD-6AL, March Pulleys, Hotchkis STB, Spohn LCA brackets, Cutout, G-MAF, straight-pipe'd cat. (for the track only of course , MAC LCA's & Panhard Rod, Susp. Tech. springs, 287 RWHP / 321 FT. LBS.,
member, http://www.teamnwfbody.org
My page: http://camaroz28.cardomain.com/id/compstall
Old Aug 30, 2002 | 03:53 PM
Post
Well I don't know what my original settings were. I had put Baer bumpstops in and had it aligned yrs back. Never had uneven tire wear only a slight wear on the edges when at the track pushing hard.
I think I'm going to go -2 w/ camber I can always change it later if I don't like it.
Old Aug 31, 2002 | 12:30 AM
I CORNER's Avatar
Post
I have been running -1.5 deg camber for 3 years on Bridgestone RE-71's, Yokohama AVS Intermediates, Advan A032Rs and Kumho Victoracer 700 275mm front tires with perfectly even tire wear. ... And with $4500+ of suspension upgrades (not including a few sets of wheels/tires or labor) using all spherical bearing or rod-end connections/pivot points, I assure you that I love to feel G's on every corner I can find. Based on my even wear patterns, you could probably go with a little more Camber. However, depending on the flatness and rigidity of your wheels/tires, your braking may get a little twitchy if you go too far.
I don't recall my Castor settings off hand. I went with LG Motorsports values for the Castor.
As for as Toe, in my opinion:
Toe out - good for autocross, but twitchy on the highway. Zero toe - good compromise, but still a little twitchy at higher speeds and best for drags. Toe in - better for high speed stability and not as responsive on autocross.
Rick R
Old Aug 31, 2002 | 02:56 PM
Thumbs up
Well I went w/ -2.1 camber, +3.5 castor and 0 toe. Rides well from what I can tell and tracks a little at medium speed. Nothing I haven't dealt w/ before. Now another problem. But I'll make it a new topic.
Thanks guys for the inputs.
Old Sep 1, 2002 | 05:34 PM
Dr.Mudge's Avatar
Post
I went -1.5º camber and wish I had more, was also told to go with 1/16" toe out which I didn't know at the time, car pushes without it and was told this helps.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
sscott
Jan 17, 2015 04:30 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
