Autocross and Road Racing Technique There is more to life than a straight line
Power Steering cooler
Old Sep 24, 2003 | 11:40 AM
  #16
steve-d's Avatar
PS cooler: Supposedly Std on '02 TA coupe
Just looked at the '02 catalog and it lists the PS Cooler as std. Where is it?
SD
Old Sep 28, 2003 | 09:25 AM
  #17
mitchntx's Avatar
Originally posted by 94bird
They don't make them for LT1 cars, but when I tried to call earlier this year to see if they could make something up for us I never got through.
Looking at a pump off of an LT1 car and an LS1 car (not side by side, from memory), it appears the pump is identical. Each mounts to a different bracket and obviously, the reservoir attaches differently, but the pump itself appears to be the same.
I would imagine some creative plumbing would make it work just fine.
Old Sep 28, 2003 | 10:43 AM
  #18
94bird's Avatar
The LS1 pump may very well work, but it might be a winter project if I have time. I think I've made the decision my season's over, so let the teardown begin. Since Garrett's started crawling and is close to walking now my car prep time has lessened a LOT. The car will still be there every day, but right now I have more fun with Garrett. Maybe when he gets a little older he can have a little creeper and he can help me out.
Old Sep 29, 2003 | 06:34 AM
  #19
mitchntx's Avatar
Mike, kiddos take precedent over almost everything. The time you spend NOW will pay big dividends later.
I had kids in my EARLY 20s and basically put everything on hold till I was close to 40.
It sounds like a sacrifice, and I guess it is in a way. But I wouldn't trade a second of it ...
If you want a trashed LS1 pump to use as a mock up, I have one.
Old Sep 29, 2003 | 09:43 AM
  #20
WOT's Avatar
WOT
I should tell you I had a perma-cool tranny cooler like the one pictured (it has spiraled metal inside of the cooler tubes.) I eventually developed metal in the PS reservoir which ceased after I bypassed the cooler. I just won an ebay auction for the factory LS1 ps cooler for $32.
Old Sep 29, 2003 | 11:32 PM
  #21
JSK333's Avatar
I run a small Perma-Cool on the air dam, using the existing bolts. It works well. The part # is on my website.
I also just added an underdrive crank pulley, which will help a lot too.
Injuneer
May 15, 2015 08:45 AM
mspennyhughes
Mar 1, 2015 03:50 PM
