Autocross and Road Racing Technique There is more to life than a straight line
Panhard brace
Old Jun 11, 2003 | 06:47 PM
chuck's Avatar
Panhard brace
Somehow my exhaust has smacked the panhard brace hard enough to bend it (axle hop???). I remember some discussion a while ago about aftermarket braces for this that afforded more room, say for duals over the axle. I can't seem to find any info. Should I just find a used stocker?
Old Jun 11, 2003 | 06:49 PM
CaptainMidway's Avatar
Hey Chuck check out Jason Swindle's site. Unbalanced Engineering
Old Jun 13, 2003 | 11:13 PM
DWoodAudio's Avatar
Granatelli Motorsports made the one I have on my car. The only problem with it was they way they strenghten it is by welding a flat plate to the bottom of a stock brace to strenghten it. This is all fine and good if your car is at stock ride height and doesn't have a larger-than-stock diameter panhard rod. If your car is lowered and is using a beefier aftermarket panhard rod it hits the bracing on the brace. I had to cut a relief out of mine to keep the panhard rod from hitting it under suspension compression.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
