Autocross and Road Racing Technique There is more to life than a straight line
PA front control arm wont fit!
Old Aug 28, 2002 | 07:27 PM
Red_94Formula's Avatar
Angry PA front control arm wont fit!
the front spherical rod end bushing is too long, by about 1/2 inch, to fit into my new PA k arm. the stock control arms fit in there so i know it must be the PA control arms. any one have any experince with this problem?
on a side note i had to modify the K-arm to make the drivers motor mount bolt in. errr
Red 1994 Formula (V8,M6,3.23)
K&N fipk,MSD coil,Hooker Exaust,SLP 1 3/4 headers,LT4 KM,CAM 220/229 .547/.544 112LS,Taylor Wires OVC,160°T-Stat,LT1 Edit,ZR1 rims 315's,EGR!,AIR!,Meziere H2O Pump,3"Cut Out,Power slot rotors,Earl's Brake Lines,Mac Girdle,!CAT,M6 Conversion,SCR SFCs,!MAF,MAC LCAs,Kirban Shifter,!ALT,200 Amp Alt,7/16's 1.5RRs,NGK TR55's,SLP STB,Polyurethane bushings everywhere,SLP Bilstiens,Susp Tech springs #63045
Best 1/4 13.47@103.87 (no where near current)
Installing:SLP flywheel+RPS clutch,3.73's,Auburn Posi,light weight starter, MS PA K-member+A-arms,Trans Am body, LS1 drive shaft, Rebuilt T-56
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dbrockma
Feb 16, 2015 02:56 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
thenewkid
Nov 27, 2014 09:41 AM
