No difference in handling after Subfreme connectors. Why??
Just so happens I know one of the SLP engineers who worked on the 35mm bar design. Here's his comments. Very interesting stuff:
Mike, I was the DNR Engineer on the 35mm (7mm wall thickness) Gen.IV F-car front sway bar while I was @ SLP. The Production 1LE 35mm bar (my design) used special end links (the hardest that ITT makes) and teflon lined bar to body bushings that fit the production bushing bracket. The mount for the bushing bracket was a re-inforced production piece (this part is vital with either bar). That bar & end links were worth ~ 1.5 sec./lap @ Grattan.
The bar you are talking about is 1 of Herb Adams' kluge jobs. It was slated for production, but since we could never get it to pass rough road durability testing, I got stuck with fixing it!! His bar was of a thinner wall 4130 tubing vs my released, tested, & certified 1LE 35mm bar that bolted on to a production chassis-safely!! The Heim joint design did not have a large enough range of motion IN THE HEIM JOINTS!!!! We were forever popping holes in the LCA's, breaking bars, breaking "frame" mounts, etc. The last straw on the Heim joint design was cost!! It, the bar alone, was around $225 SLP cost. The 1LE 35mm bar was down to ~$165 in "high" volumes. To be fair to Herb, his bar design was probably stiffer than mine, but it only MIGHT work on a lowered, stiffly sprung, stiffly shocked car.
He gave me a lead on a company that might be able to produce his original design, and it sounds promising. Just to be different, I'm going to follow up on it and see what I find. Sounds like this guy's 35mm hollow bar will work with the normal 1LE endlinks.
1.5 seconds a lap isn't shabby at all. Makes me want to keep my 35mm bar....
Also remember, the bar stiffness increases by the 4th power of the bar diameter. So even if the 32.5mm bar was SOLID, it's nowhere as stiff as the 35mm, much less a hollow 32.5mm. Remember, I had (and sold) a 32.5mm hollow bar. I can vouch first hand for the difference. I made all my suspension changes EXCEPT the front bar (Sam was a little slow... just kidding Sam!!!). It finally arrived and I had it installed. WOW! What a difference. Instantly noticable!!! It complimented the rest of the suspension perfectly.
Obviously you and I aren't going to agree here, which is fine, but I sure wish you could at least try the 35mm, especially on the track. I'd love to see the difference in your track times. You never know, it might be 1.5 seconds too!!!!!
I'll say this: We've tried using stock end-link on the ST bar, and broken them every time. Snapped, like twigs, gone off the car in a few cases....... Just not strong enough to handle the roll stiffness in that bar. So, if the SLP 35 isn't breaking them, there is a clear difference in stiffness between them.
I'm doing my level best to get a hollow 35 made. I had a prototype done, but some bends weren't up to my liking and I'm having a miserable time getting it changed. If it ever gets done, it'll probably be less than $200. Hopefully it'll happen.
I'd prefer a hollow 36 for a decent price, much like Hotchkis has, but won't sell without that oversized rear..... But that's another matter.
Until then, I'll carry the extra 17 pounds or so and save a couple of hundred bucks....... The roll stiffness is more important than the weight IMHO.
FYI, I've gotten some of SLP's "bushing bracket was a re-inforced production piece", it's so easy to do it's sad. I had modified some of my own prior to seeing SLP's, and beefed them up even more than they did. Just a metal plated welded in vertically to brace two of the legs. We added a second plate and braced all 4.
And yes, 1.5 seconds a lap ain't too shabby. Nice to see some props from folks running on the track for that bar that was just too big........ It's happened on LS1.com and now they fellow who worked for SLP mentioned it was a bunch quicker than with a smaller bar..... Whew, vindication.
Until then, I'll carry the extra 17 pounds or so and save a couple of hundred bucks....... The roll stiffness is more important than the weight IMHO.FYI, I've gotten some of SLP's "bushing bracket was a re-inforced production piece", it's so easy to do it's sad. I had modified some of my own prior to seeing SLP's, and beefed them up even more than they did. Just a metal plated welded in vertically to brace two of the legs. We added a second plate and braced all 4.
Not me. That car in the example was running stock springs. Different comparison altogether.
Yes, I know. I was assuming the Hotchkiss bar the guy was talking about was 35mm OD and hollow. If I'm wrong, I misunderstood.
What I read above is all the endlinks and bushing brackets were upgraded for the original SLP design, and the one that is currently being sold uses heim joints. I'm not sure I understand your conclusion.
You can't use your marketing savvy to get Hotchkiss to sell the front bar by itself? I'll buy one if you can, and I bet others would also. I'd try it next year if I didn't have the big weight penalty to pay along with it. I can always go back to my 450 front springs if it's too much for my driving style.
If you get one it will not be nearly as stiff as the 35 solid.... just keep that in mind. Personally, I don't think that saving 17 lbs (unless you're Mike) is worth the trade-off.
WOT, I backward calculated that to a wall thickness of about 4mm (.157") based upon an advertised diameter of 36.5mm. Probably not exact, but it should be pretty close.
Jon, so based on the posts on this forum and the other one I take it you're going to try the Hotchkiss bar system instead of just the front bar? What's the going rate for that combo and did you happen to ask if there was a way to just buy the front bar?
Yup, I'm going to try them both. TByrne has the set for $419 (what do you think you could get them for, Sam?) which isn't too bad if both bars work well.
If not, I should always be able to sell the rear to a dragracer and the front to an autocrosser.
But right now I think they should work together well for roadcourse work. Time to see for myself....
I think I'll pick up a couple of extra brackets and see how it goes. The bigger rear bar and stiffer springs will reduce the loads on the brackets, all else being equal. However, tracks that require shortcuts over curbs may mean things aren't quite equal....
[/b]
You can't use your marketing savvy to get Hotchkiss to sell the front bar by itself? I'll buy one if you can, and I bet others would also. I'd try it next year if I didn't have the big weight penalty to pay along with it. I can always go back to my 450 front springs if it's too much for my driving style. [/B]
[/b]
I'm working on a hollow bar, really. But since the ST is out there, and works, and is cost-effective, and isn't tons heavier than a hollow bar, I'm not going to rush into something that doesn't fit to my satisfaction.
For the FRONT bar it came out to be a bit over 6.25mm, or .250" wall thickness.
Sorry guys. I guess that's what I get for trying to hurry a post when my wife is calling me for dinner.
