Need Suspension advice.....
What all do I need to do to a stock set-up to make it stronger and able to take curves, etc....? I know springs and shocks, but what else? And about how much money is it going to take to get everything done. I can do all the work myself. Also what brand should i get? Thanks
-Buck
-Buck
You want to start with with the Struts and shocks, and use good ones. Koni and Bilstein are the best for the 3rd gen. After that, since the car is a V-6, it's be time to start upgrading swaybars. This is asssuming your bushings are all in good shape, if not you want to change them either with or just after your struts and shocks.
3rd gen spring rates are actually quite good, and would be very low on my list of things to change on a stock 3rd gen suspension.
RUENUF
Mar 13, 2016 03:37 PM
