Autocross and Road Racing Technique There is more to life than a straight line
K-members and A-arms
Old Jan 8, 2003 | 08:57 AM
Gripenfelter's Avatar
Besides the obvious weight reduction, how else do these parts benefit your car?
Old Jan 8, 2003 | 02:31 PM
Dr.Mudge's Avatar
Kmember, space, A arms I think offer more camber gain dont they?
Old Jan 8, 2003 | 03:56 PM
steve_c's Avatar
k-member is a weight reduction, probably only useful for drag racing.
Also you don't know how they relocate the lower a-arms, which could cause geometry problems and alignment issues.
Lower a-arms are a good mod, provided they use spherical bearings or rod ends.
LG makes lower a-arms with rod ends, GW makes a spherical bearing kit.
Both are probably the best on the market for our cars right now.
Steve
Old Jan 8, 2003 | 04:22 PM
RdRacerZ28's Avatar
I've installed the BMR upper and lower control arms and also the K-member one a couple cars and liked them. Both cars are used for auto-X. The car seemed to sit a little lower in the front and also they change the upper ball-joint angle so it's correct when the car is lowered. Install was not bad at all except for no brackets for the brake lines on the K-member. Would have been nice if they'd put those on there.
Old Jan 8, 2003 | 04:23 PM
Dr.Mudge's Avatar
Weight reduction rules in all motorsports, except maybe tractor pulling and monster trucks
You'd get some lower weight, and improved distribution, win-win. It seems most suggested to use mild steel instead of moly for the street, so keep that in mind, or ask around.
Again, space gained with k-member, usefull for LTs.
97blackformula
Aug 27, 2015 06:02 PM
Killer
Oct 1, 2003 08:34 AM
JD30thZ28
Pacific
Jun 5, 2003 11:25 AM
simple
Mar 10, 2003 10:30 AM
Slowhawk
New England Area
18
Feb 18, 2003 10:26 AM
