Autocross and Road Racing Technique There is more to life than a straight line
installed bilstein hd's: slightly disappointed
Old Nov 10, 2003 | 05:30 PM
1.8ttolt1's Avatar
i installed some bilstein hd's which replaced 130,000 mile original decarbons. i have no other suspension mods. anyways i would not reccomend them for any sort of performance application. definitely go with revalved bilsteins or konis. the compression and rebound are quite a bit softer than what i was expecting. they did cut down on body roll a bit and the rebound is better. if you are purchasing the hd's for a daily driver without any real sporting intention they are better than the factory shocks and for $285 are inexpensive. hopefully a 35mm front way will help things out a bit.
Old Nov 10, 2003 | 06:42 PM
stereomandan's Avatar
Yes, they are not a monstrous change, but a very good change. For me, anything with a stiffer shock would be pretty annoying in a daily driver. I'm also waiting on the 35mm ST bar, which should make a big difference.
Dan
Old Nov 10, 2003 | 09:41 PM
TA Dreaming's Avatar
they made a world of difference on my car, but im lowered. worked great in the mountains, i love them. but the best part about them is they can be rebuilt and revalved at a later date. so i made a small change at first. ill see about revalving them later. sorry you didnt like them so much. trey
Nov 18, 2023 07:21 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
edman
Jan 22, 2015 02:45 PM
