Autocross and Road Racing Technique There is more to life than a straight line
Help,Front Strut replacement
Old Aug 19, 2003 | 07:48 PM
gchris's Avatar
2000 SS:
Having trouble removing the strut/shock from the upper
bracket.
The nut on the top of the shock was completely rusted
together... I got that off, with a cut-off wheel....
Now, I assume that the bracket should slide off ??? Not
Happening.
Has anyone had any experience with this ?
Old Aug 19, 2003 | 09:48 PM
LPEdave's Avatar
You have the spring compressed, I hope? That nut is all that holds the top bracket on, so I'm surprised it's not off already...
Dave
Old Aug 20, 2003 | 07:04 AM
gchris's Avatar
Yes,,, the whole things apart... I cut shock in half and
cut the spring off . Whats left is the top of the shock and
the bracket... I'm sure I will need a new bracket.
The old shaft is just fused into the bracket.
Old Aug 20, 2003 | 08:17 AM
poSSum's Avatar
Disciple
Have you tried heat and an impact hammer?!?
When we took the original suspension out of my 99 the nut had fused to the shock ...ended up breaking the shaft on the shock ...but everything else came apart okay.
Anyone have a suggestion as to what the best lube/anti-sieze would be in this area to prevent it from happening again? Seems to be a natural pocket for collecting moisture and grit
Old Aug 20, 2003 | 08:34 AM
chevroletfreak's Avatar
When I replaced mine, I just put a gob of grease on it. I hope it will help in the future. I havent had any problem with it loosening....I dont think.
Old Aug 20, 2003 | 08:54 AM
stereomandan's Avatar
A few good hits with a hammer in that area should loosen it up, if the nut is completely gone, like you say. I assume this is the passenger side? They like to get water in there for some reason.
Remember, the nut has a little flange on the bottom. I thought I had cut all the way through mine, but then I noticed the little flange on the nut and cut through that too. Then I hammered off the nut, and it came apart real easy. Like I said, a hammer should do the trick, as long as the nut really is completely off.
Dan
Old Aug 20, 2003 | 09:46 AM
LPEdave's Avatar
Yep, huge glob of grease is the standard answer...
Dave
dbrockma
Feb 16, 2015 02:56 PM
dale3in98
Feb 14, 2015 12:18 PM
Jazsun
Dec 29, 2014 12:14 PM
Jibberish18
Aug 28, 2002 12:46 PM
