Differences in styles of subframes??
What's the difference between the double-diamond style subframe connectors and the style that BMR sells?
Which is better?
Thanks!
Brian
A4 w/3.73, Hypertech, Loudmouth cat-back, !MAF, K&N cai, air foil, APC clear corners, Voxx Argus 17x9s, Eibach Pro-kit, BMR relocation brackets, BMR adj panhard rod
8.685@80.538
13.561@100.690
Which is better?
Thanks!
Brian
8.685@80.538
13.561@100.690
BMR are tubular and have no cross connect, I figure if your going to get a cage someday then boxed subframes are probably not neccessary or as neccessary/benefitial.
If you AutoX any subframe will probably move you around, and boxed even higher than tubular.
The double diamonds attach to the middle of the floorpan as well as the sides, distributing the load over a wider area. Whether that is worth the cost and the weight is something no one can prove, one way or another.
2000 Firebird convert, chameleon/tan, M5, Y87, TCS
KBDDs, BMR STB and Panhard, 245/50-16 GSCs
What I meant was DD design, but also boxed tubing like BMR offers can maybe throw you in a class up over tubular, I have thier tubular FWIW and I am happy with them.
If you autoX there are rules about what modifications are legal and in what class they are legal lest you be outplaced into another.
carguyshu
Jan 22, 2017 11:19 AM
CARiD
May 6, 2015 07:49 AM
