Autocross and Road Racing Technique There is more to life than a straight line
Couple of questions about LCA Relocation Brackets??
Old Jan 1, 2003 | 05:09 PM
ninjatertl's Avatar
From: In the Sewer with the Splinter & the other turtles
First i was wondering if there was a noticeable difference in the BMR and the Sphon relocation brackets and does it really matter which ones to get?
Second, i dont plan on lowering my car so i was going to buy the BMR PHR and LCA's, do you think it is worth is to buy the relocation brackets as well? or should i just stick to the PHR & LCA's?
Old Jan 1, 2003 | 10:23 PM
I CORNER1's Avatar
I use the Global West rear LCA relocation brackets and they fit fine. I don't know about the others.
Unless you are lowering your car, the relocation brackets will not do you any good; unless all you do is drag race.
I would still invest another $30 to $50 in an adjustable panhard rod bar. At some point you may decide to lower the car or simply use the adjustment to center the axle for really wide tires.
If you want your car to handle around corners, stay away from poly on the rear LCAs.
HectorM52
Jun 23, 2016 08:42 PM
lbrowne
Nov 13, 2011 04:25 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
