Bushings and Endlinks
I just picked up a 32mm ws6 front swaybar and I was wondering:
1.) where you guys go to buy bushings and endlinks. I see that bmr and jeg's sell poly kits but can I pick up some ES kits from the local auto parts store?
2.) Should I grease the endlinks upon install?
3.) Is there much, if any difference in hollow and solid swaybars?
1) If you've got a decent auto parts store, they probably carry the ES poly end links. They may carry just the bushings, in which case you can buy the bolts and spacers at a hardware store
2) No
3) A solid bar is a bit stiffer than a hollow bar of the same diameter, but of course it's a lot heavier. Your choice, depending on what you're trying to get done. A good hollow bar is going to be expensive...
Dave
2) No
Dave
sleeperZ96BT
Sep 9, 2015 08:28 AM
MustangEater82
Jul 13, 2002 01:28 AM
