Attn: Road racers
This question is for you A sedan guys. . . I have a 93 Z28 that is completely stock, I road race the car and heard through the grapevine there is a way to keep from blowing power steering pumps by changing the pulley to a larger diameter. Is this true? if so what size pulley and what belt should I use? I have had it fail a few times at high speeds and know it neds to be replaced.
(It moans like a 70's **** star!!)
Any advice is helpfull.
The wall is a bad place to be on raceday!!!
Many guys install a cooler in the PS system to keep the fluid temp down, seems to improve the life of the pump. Do a search, there have been a couple threads on this recently and there are a couple how-to links as well. Mike
and kinda seems possible.And a bigger(smaller)
pulley would be less revolutions... under pumping @ higher rpms.But if he doesnt have a cooler he definitely needs one(thats the prob.) and as advanced as his symtoms are and the fact he's lost a pump already before his Rack will fail in due time like mine did also even after puttin a new pump/cooler in.
Yeah, I already know I have to replace the pump, but when I do I want to fix the problem right so I won't have to do this again. I already ordered the cooler and will install that on a brand new pump!
Thanks for all the help!
This is something I've always wondered about but never needed to worry about. I road raced the heck out of my car and have never had a problem with the power steering pump. I know its not cause I am not driving the car hard enough.
However, I've never heard anyone mention the pulleys. Ever since I have been racing the car I have had BBK underdrive pulleys. I wonder if this is why I have never had the problems. I just change the fluid often and beat the crap out of the car. Best of luck.
Dan
Dan
LS1 powersteering pumps seem to be more proned to failure than LT1 pumps...most likely a result of the external fluid tank.
However, I do not have a PS cooler, but I do have the underdrive pulley and I haven't any problems with my car at the track. It has puked out a little fluid when overfilled at the track though.
Re: What is a good PS fluid
Originally posted by Kris96WS6
Since were on about power steering, anyone have recomendations on good PS fluid?
Thaks
Thaks
Formula Steve
Sep 19, 2023 08:31 AM
NewsBot
Sep 30, 2015 04:20 PM
Catmaigne
Jul 14, 2015 05:17 PM
