Autocross and Road Racing Technique There is more to life than a straight line
1le end links?
Old Aug 1, 2002 | 10:53 PM
jmzlt1's Avatar
Question 1le end links?
Are 1le endlinks the same as the standard links from a 4th gen fbody? Was thinking of buying stiffer endlinks but didn't want to go with polyeurethane ones. Any info would be helpful.
96ta m6 4.10 bolt ons
303.6 rwhp/332.7 rwt
cam and ported heads coming soon...
Old Aug 29, 2002 | 07:16 AM
traces95z
Guest
Posts: n/a
Post
[QUOTE]Originally posted by jmzlt1:
[B] Are 1le endlinks the same as the standard links from a 4th gen fbody? Was thinking of buying stiffer endlinks but didn't want to go with polyeurethane ones. Any info would be helpful.
They look (color/shape)and feel(hardness) exactly the same. My conclusion is that they are identical.
95z A4 3.23 89K
In order of install: PSlot rotors/PF pads, Flowmaster CB, Moroso CAI, descreened MAF, TB bypass, BMR STB, GMS LCA, 1LE sway bars w/Prothane Bushings, BMR SFC, cutout, BMR PHR
Old Aug 29, 2002 | 12:36 PM
MustangEater82's Avatar
Post
I don't think they are, doesn't 1LE use hardre durometer rubber on there parts, stornger then rubber, but not as good as poly.
For the record I have not noticed a huge difference over my stock ride with my 1LEs sway bars and poly bushings, they also do not squick, I greased them pretty throughly beforehand.
MY poly ones over my stock ones the difference looking at them is like night and day, the poly endlinks were abour 5mm thickier, and looked much more quality made.
Old Aug 29, 2002 | 04:04 PM
traces95z
Guest
Posts: n/a
Post
The bushings are very noticeably of a harder durometer. However, the end links don't appear any different. The color, shape and texture appear exactly the same as the stock ones I took off and for the few months I had them on they wore down a couple centimeters...not good.
Yeah, poly bushings/links are a different animal in shape, hardness, etc.
Its difficult to say just how much the f/r sway bars improved the handling but I put them on the same time I put on the LCAs and all together my car is very tight. However, I need new shocks and tires I think to take full advantage of the current handling. Right now, I may be getting some binding because my rear feels somewhat unstable around turns, almost like my car is toooo tight. The rear seems to cut loose on me a bit more now with the polys on.
Old Aug 29, 2002 | 04:34 PM
chuck's Avatar
Post
The front end links off of my 2001 T/A were identical to the end links on my 1998 Z28 1LE.
2001 Trans Am M6
Old Aug 30, 2002 | 02:03 AM
Post
Ia m almost 100% sure all 1le has a harder rubber, then stock.
As for hte sways with my poly ushings, made a world of difference course I went form a form a 17mm to a 21mm me bieng a v6, but personally I don't think I will ever sell these bad boys as long as I ma driving 4th gens. These with a STB, made an even bigger difference. I am on wussy, v6 springs with ove 100k on them.
Old Sep 1, 2002 | 05:35 PM
WOT's Avatar
WOT
Post
On mine the 1LE endlinks were identical to the stockers in every way.
1994 Chevrolet Camaro B4C 5.7L LT1 V8/T56 tranny 1 of 334
2000 Chevrolet Silverado LT Z71
http://wot.50megs.com/B4C.htm
Old Sep 1, 2002 | 05:59 PM
LPEdave's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by MustangEater82:
Ia m almost 100% sure all 1le has a harder rubber, then stock.</font>
You do realize he's asking about end links?
Dave
Old Sep 2, 2002 | 12:19 AM
jmzlt1's Avatar
Wink
Thanks for the input guys. I ended up buying them and they look identical to the stock ones. No biggie, I needed new ones anyway because I broke them when installing the HAL struts.
Old Sep 4, 2002 | 02:39 PM
multicar's Avatar
Post
The z28 or 1le bushing don't last for nothing. At &lt;35k they're done. See my sig the poly replacements.
Doug
96 Z28 A4, 2.73, black w/biege cloth
SLP SFC's
BMR STB and PHR
1LE boxed LCA's and trans mount
1LE alum driveshaft
ES poly torque arm bushing
TRW front poly swaybar endlinks
Addco rear poly swaybar end-links
DrawTite receiver type trailer hitch
HarleyZ28
Oct 5, 2015 06:23 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
8T8IROC
Mar 26, 2015 09:02 PM
DrMilhouse
Aug 6, 2002 08:45 PM
sc93
Jul 26, 2002 02:02 PM
