zr-1 rims
zr-1 rims
i have the 9.5" in the back but i have the 11" in my garage without tires, the previous owner told me 305's would fit better than 315's because they dont rub. would spacers correct this or does it rub on the outer part of the well?
If the offset is 36mm, they will stick out about an inch past the fender. If you dont mind that then 315s most likely will fit with some miner mods, including rolling the fender lip and cleareancing the inner fender well.
Many people have 315s so yours should fit.
