ZO6 wheels
Old Oct 6, 2003 | 01:16 PM
J96Z's Avatar
ZO6 wheels
Is anyone running factory Z06 wheels on their car? I would like the 18x10.5 on the back. What is the factory fron size? Just wondering If the factory gm wheels will bolt up with no problems. My car is lowered with DMS springs.
Old Oct 6, 2003 | 01:42 PM
94BlackBowtie's Avatar
You will most likely have rubbing issues. The backspacing is a little different - so it can cause problems.
Old Oct 6, 2003 | 02:21 PM
Stock Z06's are 18x10.5 58mm offset in the back and 17x9.5 54mm offset in the front. The fronts are no problem. The back has an 8.0" backspace, and that puts the wheel/tire slightly deeper in than a 17x11 GS offset wheel. That pretty much insures extensive hammering of the inner fenders, or a 1/4" spacer. But I don't like using spacers myself.
Old Oct 6, 2003 | 03:32 PM
krazzycowgirl's Avatar
the 17.9s work both on the front & the back of the 4th gen camaros. the only problem is you have to sand down the lip on the back ones that way they are not as tight going on & off.
Old Oct 6, 2003 | 04:12 PM
Re: ZO6 wheels
Originally posted by J96Z
......I would like the 18x10.5 on the back....
Old Oct 6, 2003 | 07:45 PM
Re: ZO6 wheels
That can/has been done with an offset made for our cars - but that means aftermarket Z06 wheels - not GM.
Old Oct 6, 2003 | 11:12 PM
94z28blue's Avatar
i too want some zo6 rims but im going aftermarket with 9.5 in the back to stay away from rubbing issues
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
