Z06 Rims
Old Nov 1, 2002 | 09:21 PM
tyler08's Avatar
Z06 Rims
I was looking into getting Z06 Rims and was wondering what offset that I should get. On http://www.wheelreplicas.com/z06.htm they have a set "17 x 9.5 / 18 x 10.5" and was was wondering if they would fit because they have a different offset than the one above.
Old Nov 2, 2002 | 01:01 AM
Re: Z06 Rims
You can use 9.5" wide rims with an offset in the range of 49-56mm with no problems. They show 54mm for the 9.5's.
For the 10.5" wide wheels, the 56mm they show should be OK - that is about a 7.92" backspace. I use 50mm offset with 11" wide wheels in the back - 7.93" backspace, so it looks like they have the correct numbers.
A caution... some cars require light hammering of the inner fenders with a 7.93" backspace, and the corner of the jounce bumper bracket may catch the inside of the wheel when the axle goes to full drop. Varies a lot from car to car. I know mine has been hammered and the jounce bumper bracket ground down.
With a 10.5" wide wheel, you might want to consider the use of a very thin spacer plate to keep the tires away from the inner fenders if they start to rub.
I believe the "real" Z06 10.5" wheels have a 65mm offset, which would be more of a problem, but people here are running them, so the problem can be solved, or isn't as bad as the numbers make it seem........
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
