Z06 Rims
Old Sep 9, 2003 | 07:45 AM
snakehunter's Avatar
Z06 Rims
I have a 1996 Z-28 Convertible. I have heard that the convertible will not accept 17X11ZR1 wheels in the rear. I want to put 18X9.5 Z06 wheels on the front and 18X10.5 Z06 whells in the rear. Will this work on my car? Or do I have to go with 17X9.5's all the way around?
Old Sep 9, 2003 | 07:59 AM
The 17x11 ZR1/GS offset wheels fit just fine on a 4th Gen convertible.
Old Sep 9, 2003 | 08:08 AM
Does this mean I can use the 18X10.5 Z06 Rims in the rear? The ZR1 wheels were used just as a size ezample of what I was told by Discount Tire.
Old Sep 9, 2003 | 10:20 AM
94BlackBowtie's Avatar
That means that you probably can as long as the offsets are the same - find the offset for the 17x11 ZR1/GS wheels and then the offset for the wheels you are looking at - I would guess that as little as a difference of 5mm might make a difference - just because of the larger wheel - unless you totally compensate for that with the tire (small enough tire on the 18" to equal out to the same as the tire used on the 17" that Fred mentioned above.
Here is a little calculator that might help you some.
Old Sep 9, 2003 | 01:39 PM
Which wheels look better?
AR Torque Thrust II or
Z06 chrome
Old Sep 9, 2003 | 01:49 PM
Zack's Avatar
Z06 chrome
i dont like TT all that much, so I'm gonna vote Z06's
Old Sep 9, 2003 | 10:03 PM
97TA-WS6-Con's Avatar
Re: Z06 Rims
This has got to be one of the longest running and most tenacious urban myths out there.
I was told by AFS in April '00 that the 11 x17 inch wheels would not fit a vert. Ican tell you that there is absolutely NO differance getting the 11 inch wheels to fit a vert versus a coupe.
I know of a guy with 18 x 10 inch wheels on all four corners.
http://www.geocities.com/MotorCity/1701/main.htm
Although I cannot see the details on the wheels on his website.
Old Sep 10, 2003 | 10:40 AM
tbyrne's Avatar
18x10.5s all around with no rubbing -
It is a tight fit around the jounce bumper when the car is in the air. If needed you could use a 1/8" spacer to get a little more room in there.
Old Sep 10, 2003 | 10:47 AM
350 HRSS's Avatar
Another vote for TTII's
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
