wiring up a switch
Old Feb 6, 2008 | 09:43 PM
Crows89RS's Avatar
wiring up a switch
how would i go about wiring up a switch to turn on the brights? my lever has never worked. i know I could just get a new lever, but in the end, i would bet the person selling the parted out car had never tested it, so I figured this would be easier, and I'd be hiding it out of the way anyways.
anyways, what would I need to do this? I assume i would need a two way switch of some sort and hook it up to the wiring for the brights? i'm not knowledgeable in the area of wiring or what not..
Old Feb 9, 2008 | 02:12 PM
95camaroinok's Avatar
ummmm a brand new switch is only $8. and it would be about as hard/easy to just change it than to try to wire in a generic switch. just unbolt the steering column and its about half way down on the top outside. right there with the ignition switch. Your lever just pushes a rod that sits in a peg on the actual switch... It may even just need to be adjusted. Do a search on here and you can find a LOT of info on how to do all this with pictures and more detailed instructions.
Same switch/part number 3rd or 4th gen.
Old Feb 9, 2008 | 06:49 PM
LT4Camaro's Avatar
it might not be the switch when mine stopped working it was a peice of the collum itself that broke i had to get a new colum at a junk yard for 50 bucks.
Heathen1
Jan 2, 2016 04:27 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
