Winterizing!!!
Old Nov 19, 2005 | 10:17 AM
Camaro91RS's Avatar
Winterizing!!!
well guys,
as much as I tried to avoid it, I must drive my camaro in the winter and store the trans am But the really bad part is that I don't have a garage that I can put it in, so I have to store it outside in the driveway.
So far I've thought up these steps to help winterize it
*Put rims on it with crappy tires so they don't get flat bottoms
*Disconnect negative battery cable
*Wash/Wax the hell outa it
*Bought an (expensive) car cover that says it will protect against any weather
*Bought some "Sta-Bil fogging oil and cylinder protector". They said at autozone that if I take out each plug and spray this in, it'll protect for the whole winter outside. ???
*WD-40 all hinges and latches and spray some in each exhaust pipe.
if anyone has any other idea's I would GREATLY appreciate it. Thanks a lot
Old Nov 22, 2005 | 11:38 PM
mystic-t/a's Avatar
Re: Winterizing!!!
Use a sealant instead of a wax, and do layers. Here is a link to several sealants: http://autogeek.net/was.html And here is an explination about sealants vs wax http://autogeek.net/qude101.html
Hope that helps.
You also might want to start it up every couple of weeks too.
Old Nov 24, 2005 | 11:56 AM
Camaro91RS's Avatar
Re: Winterizing!!!
wow mystic thanks a lot, that definitely changes my mind
Old Nov 24, 2005 | 04:23 PM
slayer6x6's Avatar
Re: Winterizing!!!
I like to spray all the seals with rubber care before and after the winter time to keep them from dry rotting.
Old Nov 25, 2005 | 10:51 PM
Brangeta's Avatar
Re: Winterizing!!!
Well, if you disconnect the negative battery cable, make sure you have the code to unlock the anti-theft stereo or you'll have a bad Spring.
Old Nov 25, 2005 | 11:11 PM
DiabloGT's Avatar
Re: Winterizing!!!
what do you mean?
Old Nov 26, 2005 | 11:28 AM
L44's Avatar
L44
Re: Winterizing!!!
i think he meant you will have a bad spring (as in when you start driving it) because if you disconnect the batt. an you dont have the code to unlock the stock radio in the car it will lock you out.
- did you treat the gas for the car? unless you start it up every other week or so. i forgot to do it in my bike the one year an i hadda flush the system out cuz the gas went bad. but that was from like october til april so its a lil longer then now.
- if you have a leather interior it wouldnt hurt to clean an condition it because the cold weather is going to make it stiff as hell.
- if your car cover doesnt go to the ground an cover the tires get something to cover the tires, your rotors an calipers will thank you in the spring when they arent rusted together from oxidation.
Old Nov 26, 2005 | 02:02 PM
Brangeta's Avatar
Re: Winterizing!!!
Yeah, if you have the stock radio/stereo and you disconnect the negative battery cable without having the code to unlock the radio handy, your radio will say "LOC" or something and you'll have to have the Chevy dealership unlock it for you.
Maybe you could just rent a storage thing or garage for the winter? It might be cheaper or easier than doing all this preparation.
Old Nov 26, 2005 | 06:17 PM
JasonD's Avatar
Admin Emeritus
Re: Winterizing!!!
http://web.camaross.com/forums/showthread.php?t=405497
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
maverickmk
Sep 1, 2015 09:17 PM
97SSdude
Aug 21, 2015 09:36 AM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
Cam's maro
Aug 11, 2015 07:45 AM
