wings west ground effects
Old Mar 14, 2008 | 10:15 PM
blkgagt94's Avatar
how much lower do they make the front bumper sit 4" same with the sides an back
Old Mar 15, 2008 | 04:45 PM
Counted Out's Avatar
I'm confused by the question/s.
Old Mar 15, 2008 | 10:01 PM
blkgagt94's Avatar
like how much more do the ground effects make the front bumper sit?
2"
3"
4"
Old Mar 16, 2008 | 10:23 AM
johnny6's Avatar
I don't understand what you're trying to say.......You mean how much lower will the front bumper sit? It's supposed to be even all the way around, well thats how it is with my Xenon ground effects.
Old Mar 16, 2008 | 02:16 PM
blkgagt94's Avatar
if i get a set of ground effects how much lower will the car be to the ground. how much more do they add to the bumper say if the car sits say 10" how low will it sit with the effects? front bumper
Old Mar 16, 2008 | 04:37 PM
Z28SORR's Avatar
The problem is your using the term "Sit" and "Bumper". To most people this means the stance of the car (how far the frame sits above the ground), which would only be changed if you changed the springs or wheel diameter, i.e. lowered the car.
What you want to know is how far down does the front spoiler/FX extend. I haven't actually measured mine but I believe it's about 4". However this is not the part you normally have to worry about. The Airdam which is mounted near the radiator support under the car is at least 2" lower then the stock one, and is normally the lowest part of the car.
My stock one dragged on ever bump, my RK one had to be replaced after ~two years. I've reinforced the new one in the hopes it will last a little longer.
Old Mar 17, 2008 | 02:27 AM
blkgagt94's Avatar
iam getting the wings west an its lower than the rk but that helps out thankx an i lower my car about 1.5 to 2"
Old Mar 17, 2008 | 06:48 PM
johnny6's Avatar
If you lower you're car even 1 inch those ground effects won't last you six months, i have problems enough as it is with my Xenon ground effects, trying to dodge every little pot hole.
Old Mar 17, 2008 | 09:39 PM
blkgagt94's Avatar
when i had my front on the bumper was pretty high liek 10"-12" off the ground in the front so how low will it be with the wings west an i no the side wil be lower
Old Mar 18, 2008 | 09:22 PM
jeff_is_sexy's Avatar
It brings it down about 2 inches, no more than that. I have them, and my car is lowered 1.5 and I have no trouble getting around. You just gotta be careful on some of the nasty areas where the road goes down and THEN up, if it just slopes one way you're fine.
Old Mar 18, 2008 | 10:09 PM
RKPsk8er's Avatar
I dont see why they didn't understand the question?
95chwagon
Oct 16, 2015 12:24 PM
autoxr166
Sep 25, 2015 04:21 PM
92_RS_305
Sep 8, 2015 07:47 PM
maverickmk
Sep 1, 2015 09:17 PM
