window tinting yourself???
Old Mar 5, 2003 | 08:16 PM
camaroz28_97's Avatar
ok well i had tint on all my windows but i had to remove it from the drivers side and passenger side to pass inspection . the back is still on so all i have to do is the other 2. anyone know any tricks on how to do it. i did do it myself on my blazer a long time ago and it came out good but the 2 times i have tried to do it on the camaro i have failed . i really dont want to pay $70 again just to have to take it off next year again.
Old Mar 5, 2003 | 08:37 PM
stik6shift00's Avatar
You can get a note from you Doc. saying head lights hurt your eyes at night and you NEED the window tint, A friend has all 5 windows tinted (yes even 35% on the from) just b/c of some b/s he made up
Old Mar 6, 2003 | 11:41 AM
no one knows???
Old Mar 6, 2003 | 12:45 PM
bad93z's Avatar
I know what youre saying...I've tried to do mine several times and have failed everytime
Old Mar 6, 2003 | 12:48 PM
pu12en12g's Avatar
Not a good idea.
Spend the $ and get them done right.
Old Mar 6, 2003 | 01:10 PM
stik6shift98's Avatar
i have toagree
Old Mar 6, 2003 | 03:37 PM
Bryan Smith's Avatar
Definatly have a pro do it, I had mine tinted $180 with windsheild eyebrow, lifetime warranty on fading, bubbles, ripples, etc.
Old Mar 6, 2003 | 05:40 PM
i had mine done professionally too but then i had to get them off after i had been pulled over one too many times
Old Mar 7, 2003 | 03:00 AM
Originally posted by charles brieker
i tried to but failed also and cops have nothing better to do than pull us over for having tint on are camaro's
ya thts my thoughts exactly
Old Mar 7, 2003 | 10:45 AM
slayer6x6's Avatar
the rear window is a PITA!
Old Mar 8, 2003 | 04:40 PM
1995redZ28's Avatar
actually tinting out side windows is extremely easy!! i did it on my old 95Z. came out decent. my neighbor does tinting professionally so he did mine in 5% for $80. all you have to do in order to do the sides is wet the wondow and film.... place it on the outside of the window, and cut out the shape. then we the inside of the window, pull off the clear plastic off the film and put it on the inside of the window. use a squeegie thing to push out all the water. u need to use a heat gun or a blow dryer to get the wrinkles out around the outside of the window, that keeps moving when u try to push out the water.
i say go for it. give it a shot. the film is cheap, and if you have to pull it off again, no sense of having it professionally done!!
..... the back window is a WHOLE different story!!!!
Old Mar 9, 2003 | 12:13 AM
SpeC's Avatar
uhh why would u tint the outside?
Old Mar 9, 2003 | 07:09 AM
iamsparc's Avatar
You don't tint the outside...that's how you measure your tint, and make cuts because it is easier. Once you have cut your tint to FIT the Outside....you APPLY it on the INSIDE. I thought you said you have done tint before?
-Mike
Old Mar 9, 2003 | 07:11 AM
iamsparc's Avatar
Talking my mistake
My mistake...you weren't the one that said you had done tint before. Anyways...that's how you do it.
-Mike
Old Mar 9, 2003 | 01:52 PM
tired and failed AGAIN
i tired 5% and it kept wrinkiling around the sides. i just dont get why. i had it prof. done (before i had to take it off) and watched everything they did so i know "HOW" to do it but for some reason it won't work i don't know i jsut going to have it done
