will bondo work on plastic???
Old Mar 22, 2007 | 11:01 PM
jamilz28's Avatar
i have a long very thin gash in my dash can i use bondo or what shadi i use???
Old Mar 22, 2007 | 11:37 PM
jamilz28's Avatar
do i use glazing putty???
Old Mar 23, 2007 | 05:02 AM
FireChicken1995's Avatar
id use something that strechs more like a urathane base. your dash can expand when its hot and im sure all the 3rd gen guys know what im talking about. if you use bondo its gonna most likely seperate from the plastic one day down the road. auto parts stores have dash repair kits but i donno how good they are. what color is the part at hand?
Old Mar 23, 2007 | 10:14 AM
shock6906's Avatar
I took my dash out (the one closest to the windshield) and fiberglassed the back of it. After that, I covered it in vinyl. I also broke out the slats for the defrost vent and put some wire mesh in it's place. If you want to see, check out my cardomain page. There's also a thread about this very subject that I posted in with a couple pictures.
Old Mar 23, 2007 | 11:13 AM
jamilz28's Avatar
i used some grill thing for the vent and i used dynamat on the back of the dash
here is a pic of what i have done so far
Old Mar 23, 2007 | 01:08 PM
if you fiberglass it them it will work only b/c the platsic will expand and shring under the fiberglass and the fiberglass wont give so thats a good option to go with. iv seen alot of interiors that were fiberglasses over and it looked really good. even seen rhino liner.... guess you wouldnt have to worrie about rock chips in your interior.
Old Mar 23, 2007 | 02:24 PM
MarcR94v6's Avatar
Bondo is for metal only. Use fiberglass as said above.
Old Mar 23, 2007 | 05:04 PM
Chevy16's Avatar
when i see fiberglass subwoofer boxes made ppl sand them down and then use bondo over it to keep it extra smooth
Old Mar 24, 2007 | 11:31 PM
Koby's Avatar
Where do you get the fiberglass from? I recovered my dash awhile ago, but it is cracking more and I need to do something to reinforce the back. I'm also changing the cover back to the stock color, black just looks out of place.
Old Mar 25, 2007 | 07:37 PM
transAMdriv3r's Avatar
My front bumper had some holes in it from the previous owner because of the license plate holder and I sanded down the area and applied small amount of bondo to the holes and I looked the next day and it was cracking already. I since decided to get hold of a new bumper.
Old Mar 26, 2007 | 12:07 AM
Jun10rp's Avatar
look for some stuff called smc it has a acid base and will bond to anything i use it on saturns cause of the plastic bodys
D1SC383LT4
Jan 1, 2016 01:56 PM
rjc1629
Jan 27, 2015 10:46 AM
Jason Short
Jan 19, 2015 06:34 PM
ANDYZ28
Dec 29, 2014 09:13 PM
siguy
Nov 27, 2014 10:07 AM
