Will 99 firebird V6 Rims fit on a 94 Formula?
Old Apr 11, 2003 | 10:41 PM
99gatorbird's Avatar
Question Will 99 firebird V6 Rims fit on a 94 Formula?
I have a 99 Firebird V6, with 4 wheel-disc brakes. I am selling my old rims on ebay. A guy is bidding on them who has a 1994 Formula. He also has 4 wheel disc. Will they fit? He said he bought 2002 takeoff rims and they did NOT fit his car. Said the bore was off a little. I have a another story for my rims that i am selling. I sold them to a girl with a 1995 Camaro V6, these rims fit on the front fine, but she had rear drums and they did not fit on the rear. It was off like 1/8 of a inch off. A shop in town wanted like 75 dollars a wheel to bore them out a hair. I laughed at them and went on. So my question is will they fit the formula in 1994 and what the HE** is the difference in bolt pattern and bore pattern from year to year for firebirds and camaros. I thought all firebird rims from 1993-up were the same? Thanks for all the help.
Old Apr 12, 2003 | 09:09 AM
TECHNOBETSY's Avatar
I have a 95 bird with drum breaks in the rear and i got this set of ws6 rims off a 97 trans am. the front fit but NOT the rear. the inner lids are little smaller to fit... a machine shop was gonna charge me $50+ to get them fit... i said F** that, got a dremel and sanded the S*** out of them (Did all 4) for about 3 or 4 hours... they finally fit and that was not too hard at all...
hope this helps. but if it is a formula with discs they should be just fine.
good luck
Old Apr 12, 2003 | 09:33 PM
caspergotaz28's Avatar
Originally posted by TECHNOBETSY
.......got a dremel and sanded the S*** out of them (Did all 4) for about 3 or 4 hours... they finally fit and that was not too hard at all...
Wow that seems like a really long time to bore out the rims. Maybe you are including the time to jack up the car and remove and reinstall the rims.
It should only take you 5-10 minutes of grinding per rim. You can use a dremel or a hand drill with a sanding bit to remove just a little bit of material from the center "big-hole".
Do not waste your money on a machine shop. You'd probably wanna tell your buyers about the possible grinding and what's involved.
mschmidt33
Mar 15, 2015 07:20 PM
Jan 13, 2015 09:52 PM
Jazsun
Dec 29, 2014 12:14 PM
