Widest wheel width up front?
Old Feb 4, 2004 | 09:53 PM
stang_killa94's Avatar
Can i drop a 19x9.5 inch wheel on front? What tire size is good for a 9.5 wide wheel? What about a 11" wide wheel on back? will there be any problems with rubbing or would i have to modify anything?
Old Feb 4, 2004 | 11:10 PM
KCFormula's Avatar
I know you can run a 17x11 in the front if you grind the knuckle off the front spindle. I have also seen 18x10s run up front so I would bet a 19x9.5 would fit.
Old Feb 5, 2004 | 01:53 AM
chuckys95's Avatar
19x9.5 in the front is "definetly" doable !
with the correct offset/backspacing
I am running 19x9.5's with 7 inches of backspacing on the front of my 1995 Z28 with 275/30ZR19 tires, also with Eibach "sportline" 2 inch drop springs, not a problem at all !!!!
I am also running 20x10's on the rear with 7 3/8's inches of backspacing with 285/30ZR20 tires.
pics can be seen here
http://www.cardomain.com/id/chuckys95
Old Feb 5, 2004 | 07:47 AM
pu12en12g's Avatar
20x10.5 on all 4 here
Offset / backspacing is CRITICAL like Chucky said
Old Feb 5, 2004 | 01:45 PM
Black_Z28's Avatar
Whoa, you got new rims Paul? I can't wait to see/hear it this spring.
carguy0119
Apr 11, 2016 11:11 PM
RUENUF
Mar 13, 2016 03:39 PM
akwa
Apr 5, 2015 05:09 PM
cristian1311
Mar 4, 2015 04:45 PM
dpw21562
Jan 23, 2015 04:58 PM
