Why do people use the "PINS" set-up on there hoods...??
Old Dec 1, 2002 | 03:55 PM
FilledWithFurySS's Avatar
I was wondering Why do people use the "PINS" set-up on there hoods, instead if using there stock set-up??
I have seen way to man POS's out there with this and i was just wondering..
I personally drive a LOW 12 second car and use stock latching..Is it all preferance..??
~Mike
Old Dec 1, 2002 | 06:56 PM
My car runs 12.1's with crazy MPH and alot of spin....
And i have a stock hood
Ohh well
~Mike
Old Dec 1, 2002 | 08:02 PM
97FormulaWS-6's Avatar
Well the reason they're "supossed" to be used is for fiberglass lift-off, or plastic hoods due to the extreme light weight, a typical 1 pt hold down would let the corners lift and curl up.
Although around here it has become a ricer trend to have either the stick-on fake ones, or the real ones on a metal hood
I have them on the hood of my Pro-Street car due to it being a lift-off hood, hinges won't work.
Old Dec 1, 2002 | 09:23 PM
Erik 94TransAm's Avatar
I thought it was b/c of the price difference. I was thinking about getting a ram air hood for my car-it's $600 if I wanted a regular hood, and only $300 if I wanted one with pins.
Old Dec 1, 2002 | 09:34 PM
GreenHornet1's Avatar
Where can I see some aftermarket hoods that use pins? I'm curious to compare.
Old Dec 1, 2002 | 09:54 PM
superal's Avatar
I thought they were to save weight (could remove stock hinges and front latch) and to keep the corners of the hood down at high speed.
Old Dec 1, 2002 | 10:06 PM
ReznorZ28's Avatar
I personally thought that it was just for easier access to anything under the hood. Because when I see people with hood pins for their hoods, when they work on em, they usually take the whole hood off and set it on the roof of the car.
Old Dec 1, 2002 | 10:07 PM
superal's Avatar
Yea that sounds like a good reason to have hood pins too.
Old Dec 1, 2002 | 11:48 PM
catsnet's Avatar
I don't think it's the case with the 4'th generation. it will still be the PITA to access anything
Old Dec 2, 2002 | 12:31 AM
Rich_z28's Avatar
My dad and I have them on our racecar. Basically it is just easier to lift the hood off to work on it. Instead of having to cram yourself under the down side of the hood to work on something towards the back of the motor you just lift it off. Besides its a tube frame car so it has no mounts for latches and hinges... just weld some post on the chassis and your ready to go.
Old Dec 2, 2002 | 07:24 AM
GreenHornet1: Here are some aftermarket hoods w/pins you can take a look at.
http://lt1f-body.racenet.net/dressup.php
Old Dec 2, 2002 | 09:48 AM
Brent94Z's Avatar
Super Moderator
I'm sure it is a combination of reasons...
1) Some people buy the pin on hood simply because it is cheaper and they don't want to spend anymore than they have to.
2) Hard core racers might buy the hood because it is lighter. The pin on version of the hood on my 94Z is 6 pounds lighter.
3) If you have one of those $50k engines that requires some form or another of maintenance after every run, it is easier to work on if you can just set the hood on the roof out of your way.
4) And finally, some people just want to look cool with pins sticking outta the hood yet don't want to be such a poser as to put the stick on ones on there
I don't think there is any one good reason... just depends on what you want to do.
Old Dec 2, 2002 | 11:26 AM
Thanks Erik
Old Dec 3, 2002 | 10:44 PM
Whistler's Avatar
I have a Carbon fiber hood, too. I put pins in the front to
a) look cool
b) save another10 lbs of weight off the nose by removing the latch and the associated brackets
Old Dec 4, 2002 | 07:22 AM
ZBLKHELLRZR's Avatar
Can't it make for access to people other than you? I'd hate to come out the theater or mall and find I'm 396less. LOL.
It's sweet but it seems anyone can get under the hood from the looks of it.
