white gages help
Old Feb 5, 2003 | 07:32 PM
camaroz28_97's Avatar
white gages help
i just ordered new face gages. have any tips for me.. i have had the pod out before so no prob there. but how do i get the needles off??? any tips would be helpfull im sure. thanks guys
Old Feb 5, 2003 | 08:37 PM
stangkilla1's Avatar
I would guess that you pull them out gently, but dont take "my" word for it cause I have to do the same thing with both of my Camaro's when my gauge faces come in. Let me know how it comes out.
Old Feb 5, 2003 | 09:50 PM
jare23's Avatar
same could prob. help me here too. i ordered mine and they should be in within the next 5 days.
also, if anyone knows on how to recalibrate the computer since the new gauges go to 120 and my stock go to 110?
Old Feb 6, 2003 | 12:28 AM
95Zdroptop's Avatar
I have done this twice and learned from the first time I did it.
1. To remove needles use a regular kitchen fork, just put forks teeth underneath and pull off. this ensures you are not accidently pulling on the needle but instead the black casing holding the needle.
2. Second and most IMPORTANT. First remove all panels and screws until you can remove nothing else besides the needles. Start car and let run. Take a piece of paper and write down where all the needles are normally at at ideling temperature. espically gas. Now remove the needles. Dont remove them all like I did for some reason. Defiently leave the speed needle on. Then if you can temp then gas. The reason I say this is when you go to put the needles back on you will have the car running. Now for expample you take the gas needle off and you have half a tank of gas. Now when you put it on you try to line it up with the halftank mark, but the needle will not stay where you want it. You have to keep adjusting, you will see what I mean. I messed my gas up the first time and ran out of gas. I was mad. So take my advice and you will be fine.
Old Feb 6, 2003 | 11:11 AM
ishmuff's Avatar
I didn't even remove the needles to put mine on. I just slid the white gauges over top of the stock gauge. Took about 5 mins. in all.
Old Feb 6, 2003 | 11:26 AM
z28sinx's Avatar
I would do what 95Zdroptop said, I left my needles on and tried to slide the guage over them, well I got all of the needles through except one, the gas guage, which I ended up accidentally breaking. I learned the hardway. But what I did when taking the needles off (of the new guage I had to order) is use a fork, but I used two hands, one on the fork prongs and one on the lip, and pulled straight up, rather then put the fork through and 'pry' it off. It worked well for me, and I too wrote down where the needles were for reinstall, it's been about 6 months or so and no problems yet.
Old Feb 8, 2003 | 02:44 PM
Thanks for the info, I think I'll leave the needles on (less trouble). mine for the Z28 should be in, in a couple of days cause I had to change my order (color change). I'm buying the gauge faces, gear letter piece (P R N D etc...), Heater control panel. Also I might change the bulbs while I'm in there to blue or hyper white or LED's. I heard it'll give the gauges and other lights an indiglo effect. Is this true? If it is, how do I order factory replacement colored bulbs.
Old Feb 9, 2003 | 02:11 PM
Ernster500's Avatar
What brand of faces did you guys go with? I hear MacEwen is one of the easiest to install. Is that pretty much the case? Or are they all the same?
E
Old Feb 9, 2003 | 05:41 PM
stik6shift93's Avatar
You can take the needles out just make sure you mark their position exactly, its not that much harder to do it the right way.
Old Feb 9, 2003 | 08:20 PM
The Captain's Avatar
I did this on my Sonoma. I used a fork. Just slide it in and pop it out.
Old Feb 9, 2003 | 09:51 PM
stik6shift00's Avatar
i didnt do the gauges on my camaro but i did on my old dodge stealth...just take the screws and bolts off to get the pod out..take the glass off pluss needles off put gauges in..and it might take a while to get the needles to read correct again...mess around with it..have someone drive next to you at like 20mph to see if its right..thats what i did
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:21 PM
1bad427ls1
Sep 23, 2015 01:12 AM
