where to put neons in car? and ? bout wiring
umm i have the red street glow pedals, so i dont think pottin the noens under the dash will look good, i saw someone on here that attached them to the kicker panels using the screws already there! which really makes a job easy, and lights up fron and back floorboards, my question is: what size where the neons, do u have any problems kickin them or passengers screwin em up by accident, and lastly, im gonna wire them to a light up rocker switch instead of headlights or running lights, but my main question is how would i run two neon tubes off of one switch? i could run one off of it, but i dont know how to do two??? would i jus split the power wire runnin from say the courtesy lights that are a 15 fuse and put an inline fuse on one tube? or jus ssplit the power line runnin from a 25 fuse? help would be apreciated also...good brand neons??? thanx guys
94 Z28(auto/not red, but not purple)Mods!:
K and N FIPK
Flowmaster Muffler
Hotchkis Strut Tower
Holley Airfoil
Hidden Shift Kit
Street Glow Pedals (red)
Light Silver Badges
Kenwood CD deck w/ Remote
Massive 600 watt amp
2 12" Cerwin Vegas
K and N FIPK
Flowmaster Muffler
Holley Airfoil
Hidden Shift Kit
Light Silver Badges
2 12" Cerwin Vegas
neons belong under your tires
....seriously
Brad
1997 Z28 M6
T-tops, ZR1 SS rims, all options, SLP Dual/Dual, cutout, !CAGS, FIPK, LT4 KM, Air Foil, TB bypass, pro 5.0, OBD1, !EGR, !AIR, CSI waterpump, 160* thermostat, 1LE intake elbow, PCM tuning by, www.PCMFORLESS.com , MSD superconductors, singe-cat SLP shorties minus the cat!
....seriously------------------
Brad
1997 Z28 M6
<font face="Verdana, Arial" size="2">Originally posted by turbo_Z:
....seriously
</font>
....seriously</font>
Skull-1 1997 Formula VF-1S
Protoculture:
OBD II LT1 Edit test subject #2, A4 with Motive 3.42s, LT4 Hotcam, G2 LCAs, Hotchkis panhard rod, real Bilstein shocks, Eibach Pros, Flowbastard muffler, ported + polished MAF, Mocoso CAI, Hypertech 160 thermo, TB bypass & airfoil, 1LE sway bars, poly bushings all over, exhaust cutout, BMR STB, 1997 17x9 SS wheels, NKG plugs, big block hood, BBK headers, Jacobs wires, Walbro 255 fuel pump, NX afterburner, times and ET not worth mentioning at 4000ft
"5 years down the line, if that urge comes back... I may come back. But uh, ya know that's an option that I will never close on."
Michael Jordan- October 6, 1993
General Motors F-body- August 27, 2002
http://skull-leader.cz28.com
well i wired to accesories to a 15v switch once and it blew, so i was thinkin that if i wired two neons to it,it would. now is the radio fuse 15,20, or 25v? and thats the one in the dash right? if so i know wut to do, this is for my friends z, so im not two sure bout his its a 95, which i dont think there is any difference
i have a great idea for your wiring, first you gotta get a section of about 15 feet of 4 gauge wires, the realyl really thick strong stuff, then make a loop on one end and pull the other end through to make a lasso, tie the non-looped end around your muffler, then have a buddy drive your car down the free way with the lasso around your neck, neons are gay
I love how the hypo-critical members love to bash peoples ideas just b/c some rice guys like to do it to. Those comments are unnesisary.
http://www.cardomain.com/id/marky822
Any 25v fuse should work. I have two neons on the back of the car lighting up the camaro panel (part between the tail lights). I have both of the hooked up to the cigarette lighter, so you shouldn't have a problem.
I just wanted to throw in that y'all mean 25AMP fuse. They're all 12volts.
-Eric H
**1995 White Camaro Convertible 3.4 A4 Pics!
*Leather & Power Everything
-RK-Sport Big Block Hood & Sport Wing; Custom Racing Stripes
-17x9˝" König Monsoons
-Flowmaster w/ Quad 2˝" Tips
-Viper Alarm, Pioneer DEH-P720, RF 800a2, Two RF He2 12"
-Minnesota F-Body Club
-Eric H
i didn't read all the posts, but i read the first one...i have a '95 camaro with red ground affects and red inside neons. i wired all 6 neons to my cigarette lighter fuse (i believe its a 15) and that hasn't blown yet. ground affects only require 8 amps, thats why streetglow ground affects come with a fuse built into the kit.
about wiring two neons onto one switch, just go get a 16 guage (16 guage connector if you're using 18 guage wire) connector, connect the positives from both neons and another wire leading to the switch, then do the same thing with the negatives. so basicly you hvae 3 wires in a connector thats a little bigger then the wire you're using. if you need help installing them, email me and i can tell ya how to do it.
[This message has been edited by Wolf Warrior (edited September 02, 2002).]
<font face="Verdana, Arial" size="2">Originally posted by tbehling:
i have a great idea for your wiring, first you gotta get a section of about 15 feet of 4 gauge wires, the realyl really thick strong stuff, then make a loop on one end and pull the other end through to make a lasso, tie the non-looped end around your muffler, then have a buddy drive your car down the free way with the lasso around your neck, neons are gay</font>
I got two license plate frames (green) from Autozone and wired them both to the switch in my ashtray. As far as wiring goes, both neons come w/ their own wires, so you just run both leads to the AUX leg of the switch and both grounds to the GND leg of the switch. then, using a semi-thick wire, connect the ground of your cig lighter to the ground of the switch and your lead of the cig lighter to the lead of the switch. I have both interior neons and my exterior neons all running off my cig lighter. The best thing is, the cig lighter has a fuse already so you don't have to worry about fuses and junk. Hope this helps, email me if you have any other q's.
Jay
Jaybaste7@aol.com
97 Green Z28
Jay
Jaybaste7@aol.com
97 Green Z28
