Where is a good place or where do u guys buy Caliper Paint? Or what should i do/use??
Hey guys,
im looking for some caliper paint websites or should i just use high temp engine spray? I want teal and none of the caliper paint kits have teal. I wanted to get it powdercoated, but bledding the brake lines are a PITA right?
let me know, thanks guys!
Re: Where is a good place or where do u guys buy Caliper Paint? Or what should i do/use??
Originally posted by chesee48
Hey guys,
Hey guys,
Re: Re: Where is a good place or where do u guys buy Caliper Paint? Or what should i do/use??
Originally posted by chasmanz28
i used engine paint with a good clearcoat, pep boys had the stuff
I used Duplicolor engine paint from Autozone. Although I didn't have the best expiriences painting my calipers with this paint, the final result was exceptional. If you use this paint don't let the paint dry a lot between coats. Go with about 10 minutes between coats. If you start in the morning, you could finish two calipers and have the car back together in 24 hours. You should let the paint dry well overnight so you don't chip the paint when you put the brakes back on.
I painted my calipers orange, and the mounting brackets black. And I put a clear coat over both. You can get the paint at Autozone. They have a wide range of colors, they had three shades of orange; Chevorlet orange, orange-red, and regular orange. So they should have teal, or something close to it. They also have 1200 degree paint and 500 degree paint. Both are ceramic based so they dicipate the heat better. There are more colors avaliable in the 500 degree paint than the 1200. 500 degrees is fine, the calipers won't even reach 1/3 of that.
In conclusion, Duplicolor paint from Autozone.
Good Luck
Good Luck
yeah i used regular high temp paint for my old calipers and some clear coat. it worked out very nice and looked great. i dont think that i have seen teal though, im sure it is out there somewhere though.
Hurin
Dec 13, 2014 07:38 PM
heavenly_six
Dec 10, 2014 12:23 AM
